Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
432 Discussions
what's meaning of WriteAtomicityDisableNormal ?
ychen354
I use intel memory and storage tool check my ssd properties and found this : WriteAtomicityDisableNormal. any atomic support in intel SSD? I want to learn the detail , any document can get help ?
JosafathB_Intel
Hello ychen354,
Thank you for your patience.
The following information is available on the Intel® SSD Data Center Tool (Intel® SSD DCT) and the Intel® Memory and Storage Tool user manual (https://downloadmirror.intel.com/29337/eng/Intel_Memory_And_Storage_Tool_User%20Guide-Public-342245-001US.pdf)
-WriteAtomicityDisableNormal:
(For NVMe devices only) Shows the atomic write status. One of:
 • 0: If cleared to ‘0’, the atomic write unit for normal operation shall be honored by the controller.
• 1: The host specifies that the atomic write unit for normal operation is not required and the controller shall only honor the atomic write unit for power fail operations
If you need further information related to this topic, we will appreciate if you can reply to the following questions:
- Which command (if it's from CLI tool) are you using to get SSD properties?
-We would like to know the OS that you are using.
-Please, let us know the model of the SSD you are using.
We will be looking forward to your reply.
Best regards.
Josh B.
A Contingent Worker at Intel®
JosafathB_Intel
Hello ychen354,
Thank you for contacting Intel® Memory & Storage Support.
Let us further investigate your inquiry for information related to the write atomicity in our SSDs.
We will be contacting you back as soon as we have an update, or in case further information is required.
Best regards.
Josh B.
JosafathB_Intel
Hello ychen354,
Best regards.
Josh B.
JosafathB_Intel
Hello ychen354,
We were reviewing your community thread, which is related to your Intel® SSD features, and we would like to know if you were able to review our previous post.
Have a nice day.
Best regards.
Josh B.
JosafathB_Intel
Hello ychen354,
We have not heard from you since your first post 12 days ago, please, let us know if you need further assistance related to your Intel® SSD.
Josh B.
