Community
cancel
Showing results for
Search instead for
Did you mean:
fbayi
when SFF 8639 aka U.2 cables will be available on Market
Intel selling p3700/ p3600 / p3500 series 2.5" form factor SSD / NVMe drives.. but there is a problem here although intel 750 series has sff 8639 cables in their boxes , other series has no cables .. and Intel explain the situation because of Enterprise systems has no need.. but is it forbidden to use these high-end ssd 's other than enterprise systems..
first .. why these SSD's has no cable on their boxes
second.. why these U.2 / SFF 8639 cables are not available on market / online stores..
third .. when these cables will be available..
ASouz7
Hello eczanet,
These cables are not available separately for the time being and we do not have any information if they will be available on the market any time soon. Please bear in mind that the Intel® SSD Data Center Family such as the Intel® SSD DC P3500, Intel® SSD DC P3600, Intel® SSD DC P3700 were designed to work with HBA ( Host Bus Adapter). The cable that comes with the 750 would actually work with the SFF-8639 model of the Intel® SSD DC P3500, Intel® SSD DC P3600, Intel® SSD DC P3700.
Community Manager
can you give us few links to that HBA?
i also bought P3700 and was surprised that it comes w/o any cables.
i know other people are buying 750 one only to get that cable. don't you think that's insane? or that was your main marketing idea?
Community Manager
great! thanks.
guess i'd give a try the first one.
the only few things i don't really like is that ssd's heatsink will get lower airflow, and i should also use a riser to make all that fit into 1U case.
jbenavides
Please keep in mind that Intel does not endorse or recommend the use of unofficial 3rd party adapters.
The Intel® DC SSD P3700/ P3600 / P3500 and Intel® SSD 750 Series are available in 2.5" and Add-in-Card HHHL form factors. The AiC version can be connected directly to a PCIe Gen3 x4 slot and does not require an adapter.
The 2.5 in DC P3xxx drives do not include the U.2 cable since they were originally intended for enterprise usage. Now that some motherboard manufacturers support the NVMe 2.5" SFF-8639 drives using a compatible adapter and cable, we are working to make the supported U.2 cable available, however, we do not have a specific date for this yet.
fbayi
if this adapter use pci-e 3.0 with 4 lanes... total bandwith must be around 4GB/s ..it looks like just using sata 3.0 interface .. i think pci-e lanes doesnt work at all or passive at the moment.. but i ordered this item before these photos added..when i receive my item i ll give u my results.. i have p3700 ssd..
Community Manager
waiting for your results, keeping my finger over buy button
jbenavides
Hello eczanet, I would like to add some information regarding link bandwidth.
Sata 3.0 link performance is 4.8 Gb/s (Gigabits per second), and the one for PCIe 3 x4 is around 4 GB/s (Gigabytes per second). Since each Byte contains 8 bits, 1 Gigabyte is equal to 8 Gigabits. So there is a considerable difference between SATA 3.0 and PCIe 3.0 x4.
The SATA III (revision 3) interface runs at 6.0Gb/s, with a maximum uncoded transfer rate of 4.8 Gbit/s (600 MB/s). The PCIe 3.0 performance is 7.877 Gb/s (984.6 MB/s) per lane, so, the theoretical maximum for PCIe 3.0 x4 is 31.508 Gb/s (3.9384 GB/s)
You can review the following links for more information:
https://en.wikipedia.org/wiki/Serial_ATA# SATA_revision_3.0_.286_Gbit.2Fs.2C_600_MB.2Fs.29 Serial ATA - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/PCI_Express# PCI_Express_3.x PCI Express - Wikipedia, the free encyclopedia
As you can see in the http://ark.intel.com/# @SolidStateDrives Specifications for Intel® SSD's, PCIe NVMe drives' performance exceeds the maximum possible with SATA 3.0, and high end models like the http://www.intel.ie/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec.... Intel® SSD DC P3700 Series actually use a good portion of the PCIe 3.0 x4 bandwidth.
fbayi
not that bad.. i happy with that
test system
funtin nvme pci-e adapter with intel p3700 2tb 2.5" sff
2x xeon e5 2666
asus z10pe-d16 ws
4x16GB crucial ddr4 2133mhz ecc 64gb kit
nvidia titan x
Community Manager
so you got such speeds using that Funtin adapter from amazon and it actually worth the money?
also, since you have the hottest 2tb version of p3700, what's with the heat?
i assume ssd heatsink is very close to the adapter and there's a problem with airflow.
this may become a problem?
PMitc1
Hello Jonathan, Many thanks for all your help here.
You've probably heard that a picture is worth a thousand words.
Lots of Enthusiasts are stumbling on the differences between
the 8b/10b "legacy frame" and the 128b/130b "jumbo frame"
(my choice of nomenclature / not necessarily industry standard).
It would help a lot of you could prepare a simple graphic
comparing the two frame types. We did that here
in our presentation to the Storage Developer Conference:
http://supremelaw.org/patents/BayRAMFive/SATA-IV.Presentation.pdf http://supremelaw.org/patents/BayRAMFive/SATA-IV.Presentation.pdf
(see Page 7).
I believe PC users generally understand that
a byte requires 8 bits. It's the START and STOP bits that
are confusing people. A more detailed graphic could
also illustrate the 128b/132b "jumbo frame" adopted
in the USB 3.1 specification. A good well designed graphic
will help PC users understand how PCIe 4.0 will double
raw bandwidth, using the same 128b/130b jumbo frame.
Keep up the good work!
MRFS
JPitt5
Is the cable now available from Intel? There has been several months since the last update and all Asus and MSI boards have supported this device since that time using the M2 adapter. I would hope Intel have provided for their customers in this time.
jbenavides
This request is still under consideration, however, the cable is not available separately from Intel at this time. Currently, we are not able to confirm if this will change in the future.
The U.2 interface is meant to be used with the Intel® SSD 750 Series (consumer SSD's). Even though it may be possible to find 3rd party cables on the market, these are not tested/validated as a supported configuration for Intel NVMe* Data Center SSD's.
Please check this new document that specifies what ships with the different models of Intel® PCIe NVMe drives:
http://www.intel.com/support/ssdc/hpssd/sb/CS-035797.htm Intel® High Performance Solid-State Drive — What Ships with Intel® SSD DC P3xxx Series and Intel® SSD 750 Series
JPitt5
Thanks Jonathan. What do you do when a customer has an Intel 750 with a broken cable? Do you automatically replace them under warranty?
ASouz7
rfu3,
Unfortunately the warranty is limited to the SSD only. You will need to check with your local reseller.
JPitt5
So if I was to buy an Intel 750 SSD and accidentally break the cable, since there are no retailers for this cable, including yourselves, and there is no warranty on this cable, you would expect me to buy a whole new drive? That's quite an expense for falling foul of a faulty lead. This doesn't quite meet the high level of consumer support I would expect from Intel. Are you sure this is the case?
ASouz7
rfu3,
Please check your private messages.
PHo5
Hi Aleki_intel, I am in the same boat. I need a replacement cable for my Intel SSD and I dont expect to have to buy a new hard drive just for the cable. Please assist! Thank You
ASouz7
Hello PhilipHo,
We have noticed that you also posted a thread of your own here: if both are for the same purpose we recommend to stay with only one post in order to guarantee efficiency of the support given here.
