Community
cancel
Showing results for
Search instead for
Did you mean:
RBasz
which SSD series doesn't need Trimm?
Community Manager
All PCIe series of the DC family, e.g. DC P3700 etc. are designed without the need to run trim. Although you can do so, but the action will introduce application latency, which may or may not be important to you.
Running trimming may expose other issues most NVMe SSD users are not aware of, if you use sector size different from the default 512.
Community Manager
Baszek2,
As mentioned by previous user the Intel® Solid-State Drive Data Center Family are designed for enterprise needs, where the SSD is usually active 24/7. Now, for the Data Center drives, housekeeping occurs as the drives operates without affecting its performance.
This is especially beneficial in RAID configurations, as most RAID controller don't support TRIM.
Please let us know if you need further assistance.
NC
Community Manager
Baszek2,
We are following up and we would like to know if you require any further assistance. We will be waiting for your response.
NC
RBasz
so, is the Intel SSD DC S3100 Series 480GB, 2.5in SATA 6Gb/s ok?
SSDSC2KI480H601
Thank you vm
R.Baszko
Community Manager
Baszek2,
That is correct, the Intel® SSD DC S3100 Series 480GB, 2.5in SATA 6Gb/s is fine.
NC
