cancel
Showing results for
Search instead for
Did you mean:
why my new ssd drive intel 520 120GB shows that already worked ,power on time:894813 ???
lgood1
New Contributor
11 REPLIES 11
CFran6
New Contributor II
Try some tool capable to display ATA Device Statistics log. The Power on Hours counter of this log is not affected by this bug and provides a reasonable value.
See the http://www.smartmontools.org/wiki/FAQ# ThePower_On_HoursAttributeofmynewIntelSSDreports890000hours smartmontools FAQ for a sample output.
All Intel SSDs support the Device Statistics log (introduced in ATA ACS-2) but interestingly Intel SSD toolbox is still unable to display it 🙂
lgood1
New Contributor
This is not a firmware bug 400i
I found the other drives the firmware and displayed correctly
CFran6
New Contributor II
This is not correct. Both drives are also affected by the bug. See the "Raw Values" column of ID 9. The hours are encoded in the lower 4 bytes:
000DA76E hex = 894830 decimal
000DA77C hex = 894844 decimal
The values displayed in the extra "Betriebsstunden" or "Power On Hours" field look sane because these are corrected by CrystalDiskInfo itself.
Fortunately this tool is open source, so to be convinced please have a look at the following lines in AtaSmart.cpp from CrystalDiskInfo6_2_2Src.zip:
// Workaround for Intel SSD
if (asi.Model.Find(_T("Intel")) == 0 && asi.MeasuredPowerOnHours > 0x0DA753)
asi.PowerOnRawValue -= 0x0DA753;
asi.DetectedPowerOnHours -= 0x0DA753;
asi.MeasuredPowerOnHours -= 0x0DA753;
@Intel: Could you please confirm that the offset 0x0DA753 (894803) used by CrystalDiskInfo is the correct one to compensate this bug?
jbenavides
Valued Contributor II
Hello Chrfranke,
CrystalDiskInfo is not a tool we normally use, so we cannot confirm if the values used by this tool are correct.
We advise you to confirm the power-on hours with SmartmonTools.
You can download this tool here:
http://www.smartmontools.org/wiki/Download# InstalltheWindowspackage http://www.smartmontools.org/wiki/Download# InstalltheWindowspackage
- Install the application
- Open a Command prompt with Administrator privileges.
- Change to the directory where smartmontools is installed. The default folder is c:\program files (x86)\smartmontools so the command would be:
Cd \program files (x86)\smartmontools\bin
- Run the command:
Smartctl –l devstat /dev/sda
(note, it may be /dev/sdb or other, depending on how many drives the you have installed. Also, that's lower case L after the dash in the command line)
The output will look like the picture below. Look for Power On Hours.
CFran6
New Contributor II
Hello Jonathan,
as the author of many parts of smartmontools (including the Windows port and the Device Statistics support), I'm very glad that you recommend this tool. See the Copyright line from above screenshot 🙂
My question was whether the offset used by CrystalDiskInfo is the correct one to compensate this bug in SMART attributes. I would like to add this info to the related http://www.smartmontools.org/wiki/FAQ# ThePower_On_HoursAttributeofmynewIntelSSDreports890000hours smartmontools FAQ entry.
BTW: I really don't understand why Intel SSD Toolbox does not support Device Statistics. Intel SSDs were the first devices implementing this useful feature, but the related tool still ignores it.
