cancel
Showing results for
Search instead for
Did you mean:
wicked bad perf -- drive toasted?
Esteemed Contributor III
Win 7.
C Drive: INTEL SSDSA2MH080G1GC ATA Device
D Drive: WDC WD1500ADFD-00NLR4 ATA Device (raptor)
E Drive: INTEL SSDSA1MH080G1GN ATA Device
Maybe not the most scientific test, but anything involving my c drive is slow, ... 8x slower on same-drive-copy compared to the other ssd!?
Copying 3gb ...
d to d: 2.02 mins
d to c: 3.97 mins
c to c: 8.37 mins
c to e: 1.45 mins
e to e: 1.14 mins
e to d: 1.18 mins
Is this drive toasty? Something else I should look at before I RMA?
1 ACCEPTED SOLUTION
Try moving the C: Drive to a diferent SATA Port in your mainboard.
Hope it helps
2 REPLIES 2
Hope it helps
I can't believe that actually worked! When I booted back up, windows detected and installed a new driver (weird). but then all better!
PS D:\> .\measure.ps1
d to d2.17189638833333d to c0.817919551666667c to c0.641781298333333c to e0.815604361666667e to e1.14268856833333e to d1.11123817666667
