Community
cancel
Showing results for
Search instead for
Did you mean:
jkwon2
write performance of NVMe PCIe 750 SSD 400G using fio under Linux
I want IOPS result using fio.
I read the
/message/313153# 313153 Anyone measured the performance of NVMe PCIe 750 SSD using fio under Linux?
so I edit fio parameter
fio write parameter
[global]
name=fioTestNVME
filename=/dev/nvme0n1
ioengine=libaio
direct=1
bs=4k
randrepeat=0
rw=randwrite
iodepth=32
numjobs=4
norandommap
group_reporting
[write]
runtime=600
my using command is ' fio "parameter.fio" --output fsfio220w '
I expect result in https://www.intel.co.kr/content/www/kr/ko/products/memory-storage/solid-state-drives/gaming-enthusia... 인텔® SSD 750 시리즈(400GB, 1/2 높이 PCIe 3.0, 20nm, MLC)
'read' result is good but 'write' result fall short of one´s expectations
'write' result in file
what's the matter?
Is the parameter wrong?
please answer me this result's cause or right parameters
Tags (3)
Community Manager
Hello KJY,
We understand you would like to check the performance of your Intel® SSD 750 series using FIO. We would like you to please let us know if the SSD has the latest firmware installed already (8EV101H0).
If the firmware is not the latest one, please download the ISO https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool file here.
Also, please keep in mind that the SSD needs to be pre-conditioned, the performance of an SSD is at its best when the SSD is new (out-of-the-box). As the SSD fills with data, performance will degrade.
Performance degradation varies based on the workload applied to the drive. Because performance measurements vary depending on the state of the drive, performing benchmark testing on an SSD that is in an out-of box state is recommended. This can be done by erasing the drive.
The example we have for you is:
[Flush]
filename=/dev/nvmeOn1
ioengine=libaio
iodepth=16
rw=randrw
rwmixread=100
bs=4k
numjobs=1
direct=1
norandommap
rate=16m
time_based=1
runtime=600
Could you please also provide the Linux* version and kernel you are using?
We'll be waiting for your response.
Nestor C
jkwon2
Thank you for your answer
Linux Version : CentOS release 6.8
Kernel Version : Linux version 2.6.32-642.el6.x86_64 (mailto:mockbuild@worker1.bsys.centos.org mockbuild@worker1.bsys.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-17) (GCC) ) # 1 SMP Tue May 10 17:27:01 UTC 2016
Firmware Version : 8EV101H0
and I want parameters of 'randwrite'
KJY
Community Manager
Hi KJY,
Thanks for your response.
We are going to check with our proper team about this and we will keep you posted here, as soon as we receive a response.
Nestor C
jkwon2
Hi Nestor C
Thanks for your kindness response.
I can wait for your answer
Reagards,
KJY
Community Manager
Hi KJY,
We have some recommendations for you in the meantime:
-Checking the information, it seems you are using an older Kernel and since there is no Intel driver for Linux, it is very important to have the latest https://www.kernel.org/ Kernel installed.
-Can you test the SSD in the PCIe slot closest to the CPU?
-Can we have your full motherboard's model?
Nestor C
jkwon2
Hello Nestor C
I do retest let you know after update our Kernel and install intel driver
motherboard's model : Supermicro Motherboard-X10DRi
Community Manager
Hello KJY,
Thanks for letting us know.
Just to clarify, there is no Intel driver for Linux, the driver is the inbox driver that comes with the operating system.
Nestor C
jkwon2
Hi, Nestor C
I am afraid we stop this Test by my boss.
Thank you for everything you've done for me.
regards.
KJY
Community Manager
Hi KJY,
We can just wait for you until you perform the tests.
Just let us know over here so we can continue the support.
Nestor C
