Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
x25m- "raid not supported" message in toolbox?
Community Manager
I successfully updated the firmware using the tool of intel's site. followed the instructions & it confirmed the drive & after restart... the new firmware update. here's the thing - both before & after the update- the toolbox buttons will not work. & it posts a message "raid not supported" just to the right of the '74.5 gig' drive size. but I don't have a raid array??? any fixes for this?
Community Manager
maybe RAID option was enabled in the Bios?? you might want to check on that.
Community Manager
No... actually raid was disabled. it was in IDE mode. I tried switching to AHCI & then uninstalling & re-installing the toolbox... no avail.
Community Manager
oh.. by the by... I'm running an i5 cpu, 4 gigs ram, asus p7p55d motherboard. in the bios there is a setting for raid/AHCI/ide. I already had it set to ide. called intel support, they said that ahci was preferred, but that ide should work. so I tried setting it to ahci.
