Wireless
8721 Discussions
İntel Wireless Bluetooth Ve İntel Wireless AC-9462 Sürücü Güncellemeleri Ne Zaman Gelecek
EMRAH
İntel Wireless Ve İntel Wireless AC-9462 Sürücü Güncellemeleri Ne Zaman Gelecek İntel Wireless AC-9462 Wifi Kartımın Çekim Gücü Baya Zayıfladı İntel Wireless Bluetooth Desen Uzun Zamandır Güncelleme Gelmedi Bu İki Sürücü Güncellemesini Beklediğim Zaman Yeni Sürümünü Yayınlamıyor Beklemediğim Zaman Yayınlıyor Yeni Sürümü
When Will the Intel Wireless and Intel Wireless AC-9462 Driver Updates Arrive? The Attraction Power of My Intel Wireless AC-9462 Wifi Card Has Been Very Weak. Intel Wireless Bluetooth Pattern Has Not Received An Update For A Long Time. When I Wait For These Two Driver Updates, It Doesn't Release The New Version When I Expect It, It Releases The New Version When I Don't Expect It.
DeividA_Intel
Hello EMRAH,
Thank you for posting on the Intel® communities. I understand you are having Bluetooth issues and you are looking for an updated driver to fix this problem.
Before I can move forward, I would like to confirm the following:
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is the Wi-Fi working?
3. Is this a laptop or desktop computer?
4. What is the brand and model name of your laptop or motherboard (if desktop)?
5. What is the operating system installed as well as the version and build?
6. Intel has released a Bluetooth driver on 9/12/2023 and a Wi-Fi driver on 7/28/2023. Are these drivers giving you issues?
Our support is only provided in English. We may not be able to translate the screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
Deivid A.
DeividA_Intel
Hello EMRAH,
This follow-up is to confirm if you are still having connection issues with your Intel® Wireless-AC 9462, if so, do not forget to reply with the information requested.
Deivid A.
DeividA_Intel
Hello EMRAH,
I was checking your thread and noticed that we have not heard back from you. I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
DeividA_Intel
Hello EMRAH,
In addition to my last post, I also recommend you check with the manufacturer of your computer for further support and instructions. You may need their customized drivers for your computer to be able to work.
Deivid A.
