先是蓝牙促发蓝屏,关闭蓝牙后,Wi-Fi促发蓝屏
************* Preparing the environment for Debugger Extensions Gallery repositories ************** ExtensionRepository : Implicit UseExperimentalFeatureForNugetShare : true AllowNugetExeUpdate : true NonInteractiveNuget : true AllowNugetMSCredentialProviderInstall : true AllowParallelInitializationOfLocalRepositories : true EnableRedirectToV8JsProvider : false -- Configuring repositories ----> Repository : LocalInstalled, Enabled: true ----> Repository : UserExtensions, Enabled: true >>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds ************* Waiting for Debugger Extensions Gallery to Initialize ************** >>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.203 seconds ----> Repository : UserExtensions, Enabled: true, Packages count: 0 ----> Repository : LocalInstalled, Enabled: true, Packages count: 41 Microsoft (R) Windows Debugger Version 10.0.27553.1004 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Users\lee\Desktop\052524-7718-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available ************* Path validation summary ************** Response Time (ms) Location Deferred srv* Symbol search path is: srv* Executable search path is: Windows 10 Kernel Version 22621 MP (8 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Kernel base = 0xfffff801`52e00000 PsLoadedModuleList = 0xfffff801`53a13130 Debug session time: Sat May 25 12:15:24.017 2024 (UTC + 8:00) System Uptime: 0 days 0:07:35.821 Loading Kernel Symbols ............................................................... ................................................................ ................................................................ ........................................... Loading User Symbols Loading unloaded module list ..................... For analysis of this file, run !analyze -vnt!KeBugCheckEx: fffff801`53217f80 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffff801`56d1a0d0=000000000000009f 0: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* DRIVER_POWER_STATE_FAILURE (9f) A driver has failed to complete a power IRP within a specific time. Arguments: Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp subsystem. Arg2: 000000000000012c, Timeout in seconds. Arg3: ffffdf82aafba5c0, The thread currently holding on to the Pnp lock. Arg4: fffff80156d1a100, nt!TRIAGE_9F_PNP on Win7 and higher Debugging Details: ------------------ Implicit thread is now ffffdf82`aafba5c0 *** WARNING: Check Image - Checksum mismatch - Dump: 0x210d9b, File: 0x210e01 - C:\ProgramData\Dbg\sym\BTHport.sys\FE108757203000\BTHport.sys KEY_VALUES_STRING: 1 Key : Analysis.CPU.mSec Value: 1890 Key : Analysis.Elapsed.mSec Value: 30239 Key : Analysis.IO.Other.Mb Value: 2 Key : Analysis.IO.Read.Mb Value: 0 Key : Analysis.IO.Write.Mb Value: 3 Key : Analysis.Init.CPU.mSec Value: 218 Key : Analysis.Init.Elapsed.mSec Value: 10714 Key : Analysis.Memory.CommitPeak.Mb Value: 102 Key : Bugcheck.Code.LegacyAPI Value: 0x9f Key : Bugcheck.Code.TargetModel Value: 0x9f Key : Dump.Attributes.AsUlong Value: 1008 Key : Dump.Attributes.DiagDataWrittenToHeader Value: 1 Key : Dump.Attributes.ErrorCode Value: 0 Key : Dump.Attributes.KernelGeneratedTriageDump Value: 1 Key : Dump.Attributes.LastLine Value: Dump completed successfully. Key : Dump.Attributes.ProgressPercentage Value: 0 Key : Failure.Bucket Value: 0x9F_4_PCI_Netwtw10_IMAGE_pci.sys Key : Failure.Hash Value: {2a58d4d5-f378-7953-8166-fca84d1868fe} Key : Hardware.BusType Value: PCI Key : Hardware.DeviceID Value: DEV_A0F0 Key : Hardware.HardwareID Value: PCI\VEN_8086&DEV_A0F0&SUBSYS_00748086&REV_30 Key : Hardware.RevisionID Value: REV_30 Key : Hardware.VendorID Value: VEN_8086 BUGCHECK_CODE: 9f BUGCHECK_P1: 4 BUGCHECK_P2: 12c BUGCHECK_P3: ffffdf82aafba5c0 BUGCHECK_P4: fffff80156d1a100 FILE_IN_CAB: 052524-7718-01.dmp DUMP_FILE_ATTRIBUTES: 0x1008 Kernel Generated Triage Dump DRVPOWERSTATE_SUBCODE: 4 HARDWARE_ID_BUS_TYPE: PCI HARDWARE_VENDOR_ID: VEN_8086 HARDWARE_DEVICE_ID: DEV_A0F0 HARDWARE_SUBSYS_ID: SUBSYS_00748086 HARDWARE_REV_ID: REV_30 HARDWARE_ID: PCI\VEN_8086&DEV_A0F0&SUBSYS_00748086&REV_30 IMAGE_NAME: pci.sys MODULE_NAME: pci FAULTING_MODULE: fffff801552c0000 pci BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: System STACK_TEXT: fffff801`56d1a0c8 fffff801`5335e638 : 00000000`0000009f 00000000`00000004 00000000`0000012c ffffdf82`aafba5c0 : nt!KeBugCheckEx fffff801`56d1a0d0 fffff801`538a512c : 00000000`00000000 fffff801`56d1a229 ffff9380`24836bf0 fffff801`56d1a229 : nt!PnpBugcheckPowerTimeout+0x70 fffff801`56d1a130 fffff801`530e5f7b : ffff9380`00000002 00000000`00000001 fffff801`00000000 00000000`00000002 : nt!PopBuildDeviceNotifyListWatchdog+0x1c fffff801`56d1a160 fffff801`530410b4 : 00000000`00000000 00000000`00000000 00000000`00000000 fffff801`4d4cb008 : nt!KiProcessExpiredTimerList+0x1eb fffff801`56d1a290 fffff801`5321cf8e : 00000000`00000000 fffff801`4d4c5180 fffff801`53b4c700 ffffdf82`a5d3d100 : nt!KiRetireDpcList+0xaf4 fffff801`56d1a540 00000000`00000000 : fffff801`56d1b000 fffff801`56d14000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x9e IMAGE_VERSION: 10.0.22621.3640 STACK_COMMAND: .cxr; .ecxr ; kb FAILURE_BUCKET_ID: 0x9F_4_PCI_Netwtw10_IMAGE_pci.sys OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {2a58d4d5-f378-7953-8166-fca84d1868fe} Followup: MachineOwner --------- NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\atlmfc.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\ObjectiveC.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\concurrency.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\cpp_rest.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\Kernel.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\stl.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\Windows.Data.Json.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\Windows.Devices.Geolocation.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\Windows.Devices.Sensors.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\Windows.Media.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\windows.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\winrt.natvis' NatVis script unloaded from 'C:\Program Files\WindowsApps\Microsoft.WinDbg_1.2402.24001.0_x64__8wekyb3d8bbwe\amd64\Visualizers\Usb4Kd.natvis'
Hello dreamonthepaper,
请注意,我们只能用英语为您提供支持。我们使用网络翻译工具来翻译此回复,因此可能存在一些不准确的翻译。
To help you with your inquiry, may I please know the specific product you are using and the system it is inserted into? You may also send us the SSU logs instead so we can be more familiar with your system configuration. I will be waiting for your reply.
Ramyer M.
I am just looking for an update regarding the information we requested. Kindly please let me know about this information so we can identify the next steps that needs to be taken to solve this issue.
Ramyer M.
We have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Norman S.
