I have problem with connection to my router. I have Linksys WRT54GL, it has newest tomato firmware. I tried nearly everything. Updating router firmware, wi-fi card drivers. Other devices can access my wi-fi network without any problem (Smartphone, Kindle, notebook). Even my laptop under Linux has no problem with connection. But under Windows 7(64bit) I need to try many times (sometimes 10 or 20) before my laptop will get connected. On newest drivers from Intel it was not possible to connect at all. The wi-fi channel is no used by anyone else. I checked it.
But the problem started some time ago. Before that, on the same configuration, everything was ok.
I also tried to change wireless card configuration- mobility(to minimum), tx power (higest), etc mode (now is g)
I'm using WPA 2 AES encryption.
Does anybody have any idea ?
Now the only thing I'm having in my mind is problem with driver but I've tried the newest one.
- Tags:
- Drivers
Hi Rafal,
As you already tried different wireless driver versions, you can try different setting to check if that can help you out, here are some links that will provide more information:
http://www.intel.com/support/wireless/wlan/4965agn/sb/CS-028449.htm http://www.intel.com/support/wireless/wlan/4965agn/sb/CS-028449.htm
http://www.intel.com/support/wireless/sb/CS-030709.htm http://www.intel.com/support/wireless/sb/CS-030709.htm
http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm?wapkw=wireless+performance http://www.intel.com/support/wireless/wlan/sb/CS-031509.htm?wapkw=wireless+performance
If you continue to experience difficulties, we would recommend contacting your system manufacturer for further assistance.
