Wireless
8636 Discussions
AC-7260 for desktop not connecting to 802.11AC signal
MSchm26
I recently installed the Dual Band Wireless-AC 7260 for desktop into my PC. It will connect to the 5GHz signal from my router (Netgear R6300) however Windows says it is connected to 802.11N and achieves a maximum speed of around 390Mbps, and I noticed that it has no IPv6 connectivity, which I had before installing the card. I have a laptop that supports AC and connects to the AC signal from my router. I have updated the drivers to the latest driver for both the router and the adapter, and receive excellent signal strength. I am running Windows 7 64bit. I have also noticed through the Intel Proset software it detects that the 5ghz signal is AC and N bands. Any help will be appreciated, thanks.
Jose_H_Intel1
Please check if you have widest channel selected in the wireless adapter properties for 5GHz.
MSchm26
I looked at the settings for my router and adapter, on the adapter the 802.11n channel width is on auto, and on my router I put the settings I saw to maximum, but have not seen any change. The settings I have for my adapter are as followed:
802.11n channel width 2.4ghz- auto
802.11n channel width 5.2ghz- auto
Adhoc Channel 802.11b/g- 1
Adhoc QoS mode- WWM enabled
ARP offload for WoLAN- Enabled
Bluetooth AMP- Enabled
GTK Rekeying for WoLAN- Enabled
HT Mode- VHT mode
Mixed mode protection- CTS-to-Self enabled
NS offload for WoLAN- Enabled
Preferred Band- Prefer 5.2Ghz band
Roaming Aggressiveness- Medium
Sleep on WoWLAN disconnect- Disabled
Transmit Power- Highest
Wake on Magic Packet- Enabled
Wake on Pattern Match- Enabled
Wireless Mode- 6. 802.11a/b/g
Is there anything that looks wrong or needs to be changed? Thanks
Jose_H_Intel1
And what speed do you get if the AP is set to 802.11n only?
MSchm26
Thanks for the help, but I do not require assistance anymore.
Jose_H_Intel1
Throughput depends of many factors like electrical noise and interference, AP configuration and drivers.
I am sorry for any inconvenience.
Jose_H_Intel1
Please do not hesitate to let us know in case you need further assistance in the future or if you have found a solution that may also help others with similar situation.
