Wireless
8664 Discussions
AC 9560 1216 form factor in : BOXNUC8I3BEK3
ZSzab5
I’d like to connect this to an external amtenna, but I cannot figure our the antenna connector type. Would anyone tell me what it is?
LeonWaksman
  1. The information about the connector you may find here.
  2. The external antenna with cable you may see here or this.
Leon
ZSzab5
Thank you Leon,
Are you absolutely sure?
If you look at this, I am talking about the smaller one, m2 1216 version that is soldered down to the MB. (I am asking this, since I have gone through several pigtail antennas last year, none of them matched the connector)
I have tried this and this
Zoltan
LeonWaksman
Hi Zoltan.
Both form factors (M.2 1216 and M.2 2230) using the same IPEX MHF4 connectors (and this). Be carefull while disconnecting or reconnecting the connectors, while there are very soft and fragile.
Leon
ZSzab5
Thank you again Leon :)
I never had issues reconnecting the built in antennas, if the pigtail antenna connector fits, it's quite easy. So on the board the connector is male, on the pigtail is female right?
I just ordered this, and this, should any of these be good?
Zoltan
LeonWaksman
Hi Zoltan
The parts you ordered should be good.
Leon
