Wireless
8011 Discussions
AC8265 WiFi BT certification of antenna
Haresh_prajapati
Hello Folk,
We are developed automotive product in which we have used ac8265 module for the WiFi and BT, For the WiFi we are planning to use 2.4ghz and 5ghz & Bluetooth.
We purchase module from below link
https://www.crazypi.com/INTEL-AC8265-JETSON-WIFI-BLUETOOTH-NIC
Now, we will go for the FCC and CE certificate and i got some regularity certificate of FCC and CE, but i couldn't find antenna specific certificate.
I need certificate in which it must mention with two antennas of the SMA type antenna.
can some please elaborate more on the antenna specific regularity certificate.
DeividA_Intel
Hello Haresh_prajapati,
I would like to let you know that we have a specific forum for this kind of issue and request, it is called the Intel Developer Zone. There you will receive the appropriate support on this and other concerns you may have related to this product.
Here you will find the links to access the website and the community forums:
As per the certificates, I recommend you to check with Dekra since they can help you with the certificates. Bear in mind that this process will be at your own cost.
I will send you Dekra information to the e-mail to the e-mail address associated with your community profile.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
