I'm using an AC8265 (8265.NGWMG.NV) as an access point and seem to be only able to get 12 clients connected to it. Is the module limited to the number of clients it can have in AP mode?
Hello carras3,
Thank you for posting on the Intel* Community.
To better assist you, please provide me with the below information:
- Are you using band 2.4GHz or 5GHz?
- How many devices do you want to connect?
- Is it possible to attach pictures to see where are the devices listed? (Screenshots to verify the configuration)
Attach the Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Maria R.
Hi Maria,
- We are using the 2.4 band. I do not think this chip supports AP mode for 5GHZ, but please let me know if it does.
- Ideally we are looking to maintain connections with up to 50 or so clients (if possible). The bare minimum we need is 25 clients. They are IOT devices that require very little bandwidth and communicate KB of data back and forth per day.
- I will try to get a picture of the connections, but the radio seems to no longer accept clients after 12 clients are connected.
- The module is running on a Ubuntu 18.04 machine. Do you have the same support utility for Linux?
Hello carras3,
Yes, you can find the Intel® System Support Utility (Intel® SSU) for Linux based systems here: https://community.intel.com/t5/Wireless/AC8265-in-Access-Point-Mode/m-p/1234590#M32419
If you are unable to run the tool, please provide us the specific motherboard/system you are using and the wireless driver version.
Also, and just to confirm, is the Wireless card an integration you made to your system?
Maria R.
Hi Maria,
The link you have above is for this ticket. But here is the pertinent info.
NVIDIA Jetson Nano 4GB
Ubuntu 18.04
Kernel 4.9.140
Driver:
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-26.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-26.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-26.ucode
firmware: iwlwifi-8000C-26.ucode
firmware: iwlwifi-9000-pu-a0-lc-a0--26.ucode
firmware: iwlwifi-9260-th-a0-jf-a0--26.ucode
firmware: iwlwifi-9000-pu-a0-jf-a0--26.ucode
firmware: iwlwifi-Qu-a0-jf-b0--26.ucode
This is the recommended card for the NVIDIA nano and uses the upstream driver provided by NVIDIA.
Hello carras3,
Thank you for the information, we will proceed to check this internally, please expect a response soon.
Maria R.
Hello carras3,
Thank you very much for waiting.
We checked this internally with our team, however, as per the information you are requesting we recommend you to check on our website Intel® Resource & Design Center, which provides technical Resources for Customers, Designers, Engineers, and Developers. Also, you are going to have access to personalized content, leverage Intel's design, and training tools, and find solutions for your industry.
Please keep in mind that you have to do the registration process to create the account on the Intel* Resource & Design Center.
2. Click “Submit” to complete the registration
Note: Clicking 'Submit' confirms your acceptance of the Intel Terms of Use and understanding of the Intel Privacy Policy.
3. On the automated email notification received from wsm-postmaster@intel.com, click on the link to verify the registration request. You will be granted immediate access to the RDC site.
Maria R.
