Wireless
8787 Discussions
AX200 M.2 1216 RESERVED/VDDIO18 usage
SunnyMatic
Pin 16 on the AX200 1216 module says RESERVED/VDDIO18. How is this supposed to be used? Is this an output or input? How is it connected internally?
IsaacQ_Intel
Dear @SunnyMatic,
We appreciate your engagement in the Intel® communities. Your concern is important to us, and we are eager to assist you.
To provide you with the most effective support, we kindly request some additional information:
  1. Could you please provide a screenshot or image that shows where you are encountering the "RESERVED/VDDIO18" usage?
Your cooperation will help us gain a clearer understanding of your situation and enable us to provide you with a more precise solution.
Warm regards,
Isaac Q.
SunnyMatic
Hi @IsaacQ_Intel
Thanks for helping with this. We are looking at the External Product Specification (EPS) for the AX200. Refer to table 3-2, pin 16 which talks about RESERVED/VDDIO18
Best,
Sunny
IsaacQ_Intel
Dear SunnyMatic
Thank you for your prompt response.
With the information you've provided, we will continue our investigation to offer you the most effective assistance.
Isaac Q.
Intel Technical Support
SunnyMatic
Thanks Isaac, I am looking forward for you updated response.
IsaacQ_Intel
Hello @SunnyMatic
Thank you for your patience.
The information should be in RDC if not there my suggestion is to contact an FAE (Field Application Engineer) through our Distributor Partner Directory.
We will close the thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Isaac Q.
