Wireless
8506 Discussions
AX200 Pinning m2 socket
tobbl
Hello, is there a data sheet with the pinout? I am currently creating a PCB and need the exact pin assignment.
Mike_Intel
Hello tobbl,
  1. Are you designing a system with embedded AX200?
  2. Can you tell us more about the design or project?
  3. What is the purpose of the machine that you are building?
Michael L.
tobbl
Hello, thank you for your quick response.
Yes, I would like to connect the AX200 module to a PCB via an m2 slot.
The product will be a controller for motors, valves, and analog or digital inputs. Communication will be via WiFi and LTE.
Unfortunately, I cannot provide any further details as it is subject to confidentiality.
In order to incorporate the module into the circuit diagram, I need the module's pinout so that I know which pins I need on the m2 slot.
Unfortunately, I couldn't find anything on the website.
Thank you very much.
