Hello.
I've had my computer for just under a year. The motherboard has been working fine up until recently. My internet had gone out due to powerlines touching and it shut off my PC. This has happened before and was never an issue. Only up until this recent time, I turned my PC back on and everything works fine. Except my wifi will randomly disconnect. It's just the computer, not my phone, not my router, no one else has an issue.
To fix it while it disconnects, all I have to do is go to my internet access tab in the bottom right, disconnect from my wifi, and then reconnect. It's a very brief blip and the interval between the disconnect is random. Maybe it'll do it twice in an hour, or it'll go a day without fail. it's very minor but it can be a huge inconvenience when I'm playing an online game or talking to a friend.
My drivers are up to date, so are my windows. I don't use Bluetooth. Wondering if there are any remedies?
Hello GarrettD,
Thank you for posting on the Intel
- Are you using a desktop or a laptop?
- Do you get any error codes in the device manager?
- Is this the original adapter that came with the system?
- Does it happen when using both 2.4GHz and 5GHz bands or just one?
- Even if you don’t use Bluetooth, have you checked if the issue also occurs when using Bluetooth or just with Wi-Fi?
Also please download and install the Intel
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel
Click on "Next", save the report and attach it to your response.
Josue O.
Hello GarrettD,
Josue O.
Hello GarrettD,
Josue O.
