Wireless
Issues related to Intel® Wireless Adapters and technologies
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
6422 Discussions
AX200 on Ubuntu 20.04 not connect to WPA2 secured WIFIs
mirkop
I'm not able to connect to a WPA protected WIFI from my laptop.
Output of lspci is
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
I'm using Ubuntu 20.04 kernel 5.6.0-1042-oem
output of command dmesg | grep iwlwifi is
[ 3.187470] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 3.198280] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-52.ucode failed with error -2
[ 3.198300] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-51.ucode failed with error -2
[ 3.198315] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 3.198426] iwlwifi 0000:03:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 3.199753] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[ 3.199755] iwlwifi 0000:03:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.199756] iwlwifi 0000:03:00.0: Found debug configuration: 0
[ 3.200093] iwlwifi 0000:03:00.0: loaded firmware version 48.4fa0041f.0 cc-a0-48.ucode op_mode iwlmvm
[ 3.229932] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 3.245963] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 3.251003] iwlwifi 0000:03:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 3.430917] iwlwifi 0000:03:00.0: base HW address: 64:bc:58:46:15:e0
[ 3.448520] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 4.567577] iwlwifi 0000:03:00.0: Applying debug destination EXTERNAL_DRAM
[ 4.746921] iwlwifi 0000:03:00.0: FW already configured (0) - re-configuring
Currently I'm able to view the availables WIFI and to connect to a WIFI without security.
If I try to connect to a WPA2 secured WIFI, connection doesn't go OK and the OS continues to show me the password panel after a while
I need some help
Thank you
Mirko
Sebastian_M_Intel
Hello mirkop,
1. The brand and model number of your system. You can also provide the Intel® System Support Utility for the Linux* Operating System for more details: https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating...
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Run the following commands and send us the outcome:
4. If the above steps don't work, collect the debug data:
Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging  to extract dmesg and trace-cmd.
If the output has value, please collect from the wiki FW dump too.
Sebastian M
Intel Customer Support Technician
mirkop
Hi Sebastian,
Laptop Lenovo p14s, Ubuntu Mate 20.04 64bit
Kernel: 5.6.0-1042-oem
uname -a
Linux saturn 5.6.0-1042-oem #46-Ubuntu SMP Thu Jan 7 00:51:04 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Original and pre-installed adapter
modinfo iwlwifi output in attachment
lsmod | grep iwlwifi
iwlwifi 368640 1 iwlmvm
cfg80211 757760 3 iwlmvm,iwlwifi,mac80211
dmesg | grep "no suitable firmware found!" -> EMPTY OUTPUT
dmesg | grep ASSERT -> EMPTY OUTPUT
Let me know if you need more informations
thank you
Mirko
Sebastian_M_Intel
Hello mirkop,
Thank you for your reply.
Please allow us to investigate this behavior internally. In the meantime, you can check the following link with some recommendation from the Ubuntu community: https://askubuntu.com/questions/1230954/cannot-connect-to-a-specific-wifi-on-ubuntu-20-04
Kindly wait for an update.
Sebastian M
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.
mirkop
Hi Sebastian,
this thread can be closed.
It seems that some of the official instructions resolved the problem.
Thank you for the support
Sebastian_M_Intel
Hello mirkop,
Thanks for the response.
I am glad to hear that the instructions of your distribution's forum helped on this.
Based on that, we will close this thread. However, if you have any additional questions, please submit a new post and we will help you.
Sebastian M
