Wireless
7674 Discussions
AX201 roaming issues, long roaming time
kessvn
we are observing long roaming times while moving in our office.
- Usually it takes 2-8 seconds to roam to another access point.
- We did a site survey to make sure that there are no coverage holes.
- 802.11 r/k/v protocols are in use
- Latest Intel drivers installed - 23.50.0.6
- Tried to run "netsh trace" but I am not too familiar with its output. Screenshot attached.
We have already opened a support ticket to our wireless AP vendor and they have identified that during the issue client device (HP 840 G8) stops sending a traffic for a short time and then initiates a new connection instead of roaming.
"Netsh trace" and Ruckus wireless support answer is attached.
kessvn
SSU output attached
JeanetteC_Intel
Hello kessvn,
Based on the SSU logs you shared, we recommend proceeding with the following action to help fix the issue:
  1. Go to Device Manager.
    1. Expand the Network Adapters category.
    2. Right-click your Intel Wireless Adapter and choose to uninstall it.
    3. Make sure that the option to Delete the driver software for this device is selected.
    4. Repeat steps A through D until the option to Delete the driver software for this device is greyed out.
  • Driver installation.
    • Locate the driver you downloaded back in Step 1 (first bullet above). Right-click the file you downloaded and select the option to Run as administrator. For additional information refer to the video above.
  • Apply the Recommended Settings for 802.11ax Connectivity
Let us know how it went, and we will wait for your reply.
Jeanette C.
JeanetteC_Intel
Hello kessvn,
We are just waiting for an update regarding the recommendations we shared to fix this issue. Kindly please let me know about this information so we can identify the next steps that need to be taken to solve this issue.
We will wait for your reply.
Jeanette C.
kessvn
I have uninstalled drivers provided by Intel and installed ones from HPE website.
Still having the same issue.
Additionaly we did a packet capture over-the-air pcap and on wired network.
What we have noticed that roaming procedure is successful and it happens in miliseconds.
The problem is that after successful roaming we can see multiple ARP requests/replies with our default gateway IP address.
At the moment we are investigating this ARP thing.
I will update this thread once I'll have more information.
kessvn
Hello again,
I've noticed strange thing regarding this roaming issue.
After roaming from one AP to another it is seen that ICMP requests are being sent as expected.
After ~5 seconds all replies comes back at the same time. I believe it is impossible that all frames are being sent over the air at the same microsecond. Looks like that NIC somehow caches all these data frames and after some time it sends all of them in one go.
However broadcast traffic (DHCP, ARP) is not affected in this case.
Pcap has been done on windows 10 PC. Screenshot attached.
JeanetteC_Intel
Hello kessvn,
Thank you for sharing these additional details and logs.  Please allow us some time to further investigate this issue we will post an update once it's available.
Feel free to let us know if you have questions or clarifications.
Jeanette C.
JeanetteC_Intel
Hello kessvn,
We are going to send an email to directly work on the issue. Please check your inbox, junk, or spam folders to make sure you won't miss it.
Jeanette C.
JeanetteC_Intel
Hello kessvn,
Please be advised that I am still doing a further investigation with our engineering team, and I will send an update is available.
Jeanette C.
JeanetteC_Intel
Hello kessvn,
Good day!
This issue is still currently under investigation. I will post an update once it's available.
Jeanette C.
