Will the AX210 or (AX200 or AX201) be able to utilize the expanded 5GHz band made effective for immediate indoor use by the FCC? https://docs.fcc.gov/public/attachments/DOC-368228A1.pdf This will increase the 160MHz channels by 50% (2 to 3) in the US, along with other channel widths.
Can this be done by firmware/driver updates or will it only be addressed by future products?
AFAIK, the driver can load updated firmware into the module. This should mean that a package update can provide you with the updates you need for band width. Unfortunately, ICS will need to verify (@Ronny_G_Intel. can you verify this?).
Hello dkyeager, Scott,
We will proceed to check this internally, please expect a response soon.
Maria R.
Hello dkyeager,
After check internally, is too early to confirm as Intel does not have an absolute answer of when this is going to be adopted. Once it is firmed then it will be announced.
Maria R.
