Wireless
8664 Discussions
AX210 has constant packet loss spikes and I have tried everything.
elliotk
Hi, I recently got a new AX210 Wi-Fi card to replace my old one that knew had broke. This new card had been working great for a few weeks, until today when I turned on my PC to find that every 1-2 minutes my packet loss spikes like crazy. Here is everything I have tried so far:
  • Turning power management off
  • Changing 802.11a/b/g Wireless Mode to 5GHz (the router in my dorm hall is 5GHz)
  • Disabling Packet Coalescing
  • Downgrading Intel Drivers to version 22.45.1.1 (I was using the newest drivers before and it wasn't working)
  • Enabling Global BG Scan blocking
I've been toying with settings for a while now and still I'm not seeing any fixes yet. I'm debating buying a USB wifi reciever just to test if the ping spikes are a WiFi issue, but has anyone had a similar problem and found a fix outside of the ones listed? Any help would be greatly appreciated.
ACarmona_Intel
Hello elliotk,
Please generate an SSU report to help me further analyze your system specifications and configurations. To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
Carmona A.
ACarmona_Intel
Hello elliotk,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
Hello elliotk,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you.
Carmona A.
ACarmona_Intel
Hello elliotk,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
