I have 2 lenovo computers on Kubuntu 23.04 with Intel Wifi6E cards, trying to connect to a CA region specific Wifi6E AP.
P360 tiny with AX211 (stock wifi card) - 6GHz is not working
X270 with AX210 - 6GHz is working correctly
Wireless card are detect without issue, and 5GHz is working fine on both.
However the P360 tiny is not able to detect 6GHz, it appears that it is not allowed to use 6GHz, although reg region is detected correctly as CA.
P360 tiny:~$ iw reg get
global
country 00: DFS-UNSET
(755 - 928 @ 2), (N/A, 20), (N/A), PASSIVE-SCAN
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country CA: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5490 - 5510 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5510 - 5530 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5530 - 5550 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5550 - 5570 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5570 - 5590 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5590 - 5610 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5610 - 5630 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5630 - 5650 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
No error observed in dmesg :
P360 tiny:~$ sudo dmesg | grep iwl
[ 9.295569] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 9.302164] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 9.302177] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 9.302562] iwlwifi 0000:00:14.3: loaded firmware version 72.a764baac.0 so-a0-gf-a0-72.ucode op_mode iwlmvm
[ 9.458637] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz, REV=0x430
[ 9.633881] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
[ 9.633914] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 9.633926] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 9.633959] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 9.634450] iwlwifi 0000:00:14.3: loaded PNVM version 181407b3
[ 9.650958] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[ 9.719505] iwlwifi 0000:00:14.3: base HW address: 08:9d:f4:90:c4:a5
[ 9.738424] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 10.825875] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x3f
[ 10.825908] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 10.825916] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[ 10.825925] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Firmware is the latest available :
P360 tiny:~$ ll /usr/lib/firmware/iwlwifi-ty-a0-gf-a0*
-rw-r--r-- 1 root root 1413868 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-59.ucode
-rw-r--r-- 1 root root 1481960 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-66.ucode
-rw-r--r-- 1 root root 1499284 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1502900 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1533444 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1594276 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1620004 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1620704 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1628828 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1683076 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 55484 Oct 2 23:04 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm
Kernel version is 6.2
P360 Tiny:~$ uname -a
Linux Pluto 6.2.0-34-generic #34-Ubuntu SMP PREEMPT_DYNAMIC Mon Sep 4 13:06:55 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
In contrast the 6GHz works on the X270, and the iw reg get results shows 6GHz usable :
X270:~$ iw reg get
global
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5490 - 5510 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5510 - 5530 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5530 - 5550 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5550 - 5570 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5570 - 5590 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5590 - 5610 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5610 - 5630 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5630 - 5650 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ, NO-320MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ, NO-320MHZ
(5815 - 5835 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, NO-320MHZ
(5945 - 5965 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(5965 - 5985 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(5985 - 6005 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6005 - 6025 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6025 - 6045 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6045 - 6065 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6065 - 6085 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6085 - 6105 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6105 - 6125 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6125 - 6145 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6145 - 6165 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6165 - 6185 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6185 - 6205 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6205 - 6225 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6225 - 6245 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6245 - 6265 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6265 - 6285 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6285 - 6305 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6305 - 6325 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6325 - 6345 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6345 - 6365 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6365 - 6385 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6385 - 6405 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6405 - 6425 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6425 - 6445 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6445 - 6465 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6465 - 6485 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6485 - 6505 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6505 - 6525 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6525 - 6545 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6545 - 6565 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6565 - 6585 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6585 - 6605 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6605 - 6625 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6625 - 6645 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6645 - 6665 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6665 - 6685 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6685 - 6705 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6705 - 6725 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6725 - 6745 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6745 - 6765 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6765 - 6785 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6785 - 6805 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6805 - 6825 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6825 - 6845 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6845 - 6865 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6865 - 6885 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6885 - 6905 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6905 - 6925 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6925 - 6945 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6945 - 6965 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(6965 - 6985 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(6985 - 7005 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(7005 - 7025 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(7025 - 7045 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-320MHZ, PASSIVE-SCAN
(7045 - 7065 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-320MHZ, PASSIVE-SCAN
(7065 - 7085 @ 40), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(7085 - 7105 @ 40), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
(7105 - 7125 @ 20), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, NO-320MHZ, PASSIVE-SCAN
X270:~$ sudo dmesg | grep iwl
[ 5.245628] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[ 5.249011] iwlwifi 0000:03:00.0: Detected crf-id 0x400410, cnv-id 0x400410 wfpm id 0x80000000
[ 5.249140] iwlwifi 0000:03:00.0: PCI dev 2725/0020, rev=0x420, rfid=0x10d000
[ 5.271643] iwlwifi 0000:03:00.0: api flags index 2 larger than supported by driver
[ 5.271668] iwlwifi 0000:03:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.41
[ 5.272143] iwlwifi 0000:03:00.0: loaded firmware version 83.e8f84e98.0 ty-a0-gf-a0-83.ucode op_mode iwlmvm
[ 5.497115] iwlwifi 0000:03:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 5.514699] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
[ 5.658657] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 5.658684] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 5.658695] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
[ 5.658713] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x1
[ 5.660444] iwlwifi 0000:03:00.0: loaded PNVM version 181407b3
[ 5.672219] iwlwifi 0000:03:00.0: Detected RF GF, rfid=0x10d000
[ 5.742379] iwlwifi 0000:03:00.0: base HW address: e8:84:a5:2c:31:57
[ 5.777425] iwlwifi 0000:03:00.0 wlp3s0: renamed from wlan0
[ 11.924946] iwlwifi 0000:03:00.0: WRT: Invalid buffer destination
[ 12.069797] iwlwifi 0000:03:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x20
[ 12.069833] iwlwifi 0000:03:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 12.069852] iwlwifi 0000:03:00.0: WFPM_AUTH_KEY_0: 0x90
[ 12.069876] iwlwifi 0000:03:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x1
[ 12.168041] iwlwifi 0000:03:00.0: Registered PHC clock: iwlwifi-PTP, with index: 1
Firmware files appears to be the same:
X270:~$ ll /usr/lib/firmware/iwlwifi-ty-a0-gf-a0*
-rw-r--r-- 1 root root 504272 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-59.ucode.zst
-rw-r--r-- 1 root root 533796 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-66.ucode.zst
-rw-r--r-- 1 root root 544119 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-72.ucode.zst
-rw-r--r-- 1 root root 545410 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-73.ucode.zst
-rw-r--r-- 1 root root 561263 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-74.ucode.zst
-rw-r--r-- 1 root root 568930 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-77.ucode.zst
-rw-r--r-- 1 root root 574893 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-78.ucode.zst
-rw-r--r-- 1 root root 574867 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-79.ucode.zst
-rw-r--r-- 1 root root 577400 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-81.ucode.zst
-rw-r--r-- 1 root root 581973 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0-83.ucode.zst
-rw-r--r-- 1 root root 7304 Sep 22 09:21 /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm.zst
What can be done to make the 6GHz available on the P360 Tiny ?
It does appears that AX211 uses different firmware files as compared to the AX210, but those are still up to date :
P360 tiny:~$ll /usr/lib/firmware/iwlwifi-so-a0-gf-a0*
-rw-r--r-- 1 root root 1560532 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-72.ucode
-rw-r--r-- 1 root root 1563692 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-73.ucode
-rw-r--r-- 1 root root 1577460 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-74.ucode
-rw-r--r-- 1 root root 1641260 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-77.ucode
-rw-r--r-- 1 root root 1667236 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-78.ucode
-rw-r--r-- 1 root root 1672988 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-79.ucode
-rw-r--r-- 1 root root 1682852 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-81.ucode
-rw-r--r-- 1 root root 1739988 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0-83.ucode
-rw-r--r-- 1 root root 55580 Sep 18 16:19 /usr/lib/firmware/iwlwifi-so-a0-gf-a0.pnvm
Hello Snowy
Thank you for posting on the Intel
We understand you have also opened another support thread with us, so, in this case, will continue to help you through that channel now. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel, in case that you have further questions, please open a new thread.
Thanks for your understanding.
Isaac Q.
