I recently purchased a few hi-res audio devices for my computer, but unfortunately neither can use this feature because my AX201 lacks ability to receive this level of compressed audio or there's simply no support which enables it to do so. I hope I don't have to purchase another BT adapter with this feature after hearing all the hype about Wi-Fi 6.
Hi @GunstarGizmo,
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. Please help me with the following information in order to assist you:
- Can you mention the model of the devices you purchase?
- To get more information from your system, please install the Intel:registered: System Support Utility (Intel:registered: SSU): https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel:registered: SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response.
Carlos L.
Hi @GunstarGizmo,
Thank you for the report. Can you also share the devices you are trying to connect, so I can look into this?
Carlos L.
The devices connect, but it's only a standard BT connection without the hi-res feature. One of the devices is the Asus ROG Strix Go BT headphones. Both devices require the same connection to utilize this.
I have a feeling that my wi-fi adapter requires a chip from Qualcomm to deliver a compressed audio stream.
Hi @GunstarGizmo,
Thank you for the information. Let me check this internally and as soon as I have more details I'll let you know
Carlos L.
Hi @GunstarGizmo,
Thank you for your time. Bluetooth's profiles are managed natively by the OS, therefore Windows supports APT-X and APT there is no need for a driver or additional software. Please contact Microsoft for more information on this.
Carlos L.
It's a codec, not a driver. The codec is on my system, but not supported by my BT module which means I'll need to purchase another BT module that actually has apt-x support. I'm not sure why Asus chose to put such a generic module on a high end board.
Hi @GunstarGizmo,
Thank you for you post. Yes, that is correct, you should not require extra hardware for it to function. Please contact Microsoft to get more support on the Bluetooth profiles.
Carlos L.
Hello @GunstarGizmo,
Carlos L.
I do require a wireless module with a Qualcomm DSP for this feature to work. This is not a Windows issue, it's an issue with the AX201 hardware which only supports SBC.
