Wireless
8607 Discussions
Availability of firmware for the BE201 combo connectivity card
chimac
As of me writing this ticket, there seems to be no firmware available for the BE201 connectivity card.
I've looked in both firmware/linux-firmware and iwlwifi/linux-firmware, branch "for-upstream" and the only firmware available for this series of cards ("Bz") is for the BE202 ("Bz-b0") and BE200 ("Gl-c0"), nothing exists for BE201 ("gl-a0"). This firmware is required for the Linux support mentioned on the Ark specification page.
shivang25
+1 on this. I am waiting for some update on this too.
Actually, for me, it shows the following through the kernel dmesg (ASUS laptop running Ubuntu 24.04, Linux 6.8 with Intel BE201 chipset):
[    2.800408] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    2.814655] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x1080900 wfpm id 0x80005b20
[    2.814662] iwlwifi 0000:00:14.3: PCI dev a840/00e4, rev=0x460, rfid=0x20112200
[    2.815788] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-86.ucode failed with error -2
[    2.815800] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-85.ucode failed with error -2
[    2.815811] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-84.ucode failed with error -2
[    2.815820] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-83.ucode failed with error -2
[    2.815829] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-82.ucode failed with error -2
[    2.816339] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-81.ucode failed with error -2
[    2.816349] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-bz-a0-fm-c0-80.ucode failed with error -2
[    2.816350] iwlwifi 0000:00:14.3: no suitable firmware found!
[    2.816805] iwlwifi 0000:00:14.3: minimum version required: iwlwifi-bz-a0-fm-c0-80
[    2.817311] iwlwifi 0000:00:14.3: maximum version supported: iwlwifi-bz-a0-fm-c0-86
So, it says that it requires the iwlwifi-bz-a0-fm-c0-* firmware rather than the gl-a0 firmware.
Dudii43
Exactly same problem here regarding iwlwifi min/max version needed.
Running Dell XPS 13 (9350) on Ubuntu 24.04.1 LTS, with Intel® Core™ Ultra 7 258V × 8, and B201 chipset
