Wireless
6717 Discussions
Ax201 with dell g3 3779
Asik
Hello.
I have dell g3 3779 notebook with with Intel 9462ac module. Could i change it to ax201? Or i should use only 9560ac module?
Steven_Intel
Hello Asik,
The board form factor needed to install the Intel® Wi-Fi 6 AX201 (Gig+) is M.2 2230, M.2 1216. In order to ensure the compatibility, I recommend you to contact Dell support for further assistance.
As well, please make sure to check the Regulatory Information Regarding Wireless Hardware Installation or Upgrade: https://www.intel.com/content/www/us/en/support/articles/000005687/wireless.html
Please let me know if you have any further concerns.
Steven G.
Steven_Intel
Steven G.
Asik
Hi Steven.
No answer for my question.
I have intel core i5 (8 gen) CPU. It supports 9560 module.
What generation of cpu i need to install ax201?
Steven_Intel
Hello Asik,
Thank you for your response.
The Intel® Wi-Fi 6 AX201 (Gig+) requires a system that supports CNVio2. This CNVio2 is available since Ice Lake chipsets, which means it is required a 10th generation processor.
Your system most likely supports CNVio, which is not compatible with the Intel® Wi-Fi 6 AX201. You can check the Intel® Wi-Fi 6 AX201 specifications in this page: https://ark.intel.com/content/www/us/en/ark/products/130293/intel-wifi-6-ax201-gig.html
Steven G.
Steven_Intel
Hello Asik,
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
