Wireless
8624 Discussions
BSOD wtih Wireless-AC 3160 on Win 8.1 64Bit and PROSet 17.13.11.5
FPret
I'm experiencing an highly reproducible fatal system error (BSOD) while streaming videos on Windows 8.1 with Wi-Fi. It happened to me 3 different times trying to watch the same video[2]. The crash is frequently marked as KERNEL_SECURITY_CHECK_FAILURE.
I enabled Driver Verifier and enabled following options for all non-Microsoft drivers. This produced a crash of type SPECIAL_POOL_DETECTED_MEMORY_CORRUPTION, with module Netwbw02.sys (PROSet driver) marked as the cause of the crash in the StackTrace below.
The full dump with analysis can be found at [1]. Windbg analysis is at [3]. Also opened a ticket at ServiceRequest.
nt!KeBugCheckEx
nt!MiCheckSpecialPoolSlop+0x8a
nt!MmFreeSpecialPool+0x14c
nt!ExFreePool+0x1b6
VerifierExt!ExFreePoolWithTag_wrapper+0x10
nt!VerifierExFreePoolWithTag+0x44
ndis!NdisFreeNetBufferList+0x114
ndis!ndisMSendNetBufferListsCompleteToNdisPackets+0x82
ndis!ndisMSendCompleteNetBufferListsInternal+0x140
ndis!NdisMSendNetBufferListsComplete+0x4f1
ndis!ndisVerifierNdisMSendNetBufferListsComplete+0x21
Netwbw02+0x1b13b1
Netwbw02+0x22372
STACK_COMMAND: kb
FOLLOWUP_IP:
Netwbw02+1b13b1
fffff801`01e683b1 eb1c jmp Netwbw02+0x1b13cf (fffff801`01e683cf)
SYMBOL_STACK_INDEX: b
SYMBOL_NAME: Netwbw02+1b13b1
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Netwbw02
IMAGE_NAME: Netwbw02.sys
[1] https://rur.it-robotics.it/temp/dump1.7z https://rur.it-robotics.it/temp/dump1.7z
[2] https://www.youtube.com/watch?v=cWn9INKTiq8 https://www.youtube.com/watch?v=cWn9INKTiq8
[3] https://rur.it-robotics.it/temp/analysis.txt https://rur.it-robotics.it/temp/analysis.txt
ASouz7
Hello ceztko,
These crashes are mainly related to memory corruption in Windows*. In the Microsoft* Communities, there is a post that might be related to the same issue you are experiencing. Please click in this link: http://answers.microsoft.com/en-us/windows/forum/windows8_1-performance/bsod-kernel-security-check-failure-on-windows-81/e663f237-b397-49e4-90b2-5316839874ce BSOD Kernel Security Check Failure on Windows 8.1 - Microsoft Community - *NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
As for your Intel® Dual Band Wireless-AC 3160, please make sure you have the latest drivers and also check for possible BIOS updates. If this card came already installed when you bought your computer, it is highly recommended that your contact your computer manufacturer to get the latest updates first.
*If you installed this card after you bought your computer, you can check the latest drivers from our download center taking into consideration your OS. Please access the link this link: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&FamilyId=1783&ProductID=3776&ProdId=3776 Intel® Download Center for the latest drivers.
*Important to know: Intel does not support integration as all wireless hardware are meant to be professionally installed by the OEM (Original Equipment Manufactures) technicians. Only your system manufacturer is entitled to provide you a list of validated and certified adapters that are compatible with your system. So, for more information you may need to contact them directly. Please access the links below for further information.
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm http://www.intel.com/support/wireless/wlan/sb/cs-011644.htm
ASouz7
Hello ceztko,
FPret
Aleki, intermediate knowledge of WinDbg/Driver Verifier plus seeing Netwbw02.sys on the call stack gave me the false illusion of having found a "smoking gun". After your answer I realized the fault was actually happening everywere, not only on ndis/wi-fi. It was indeed a memory corruption caused by a faulty memory bank, detected by memtest86[*] in few minutes. After having removed it, the system is now stable again while streaming the offending video (ugly video, but for some reasons it had a failure rate of 90%). Thanks for the help.
