Wireless
7368 Discussions
Bluetooth on 7260 Wireless-N Not Visible
TJohn9
I'm running the Samsung Ativ Series 9 Book Plus. Was installing the 7260 Wireless-N software update 17.0.1405.02. Since I did that, my Bluetooth is gone. Not visible in Device Manager, not able to connect anything, nothing... Anyone have an idea what would cause that?
Muthu_K_Intel
Window 8.1? Could you install 1405 and cold boot (shutdown /p). After booting into the OS again, you should see Generic Adapter in Device Manager. Then try installing https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24191&lang=eng&ProdId=3827 Intel® Download Center (32 or 64)? Make sure you perform cold boot between uninstall and re-install steps.
Muthu_K_Intel
TJohn9
BSon
Hey diceman,
did this work for you? Which form factor does your 7260 Card have? Mini-PCIe oder NGFF/M.2?
Cheers
Bjson
