Wireless
8606 Discussions
CNVio V3 - 700-Series PCH / Raptor Lake
ATK03
I was wondering if anyone had any information pertaining to installing a BE-series WiFi 7 card on a Raptor Lake Portable system (ie i7-1370P). I'm looking to move from a CNVio V2 radio (AX211) to a CNVio V3 radio (BE201). Is this possible, or will I need a non-CNVio radio (BE202).
I'd prefer to use the BE201 since it supports 4096QAM and the BE202 does not, and no 4096QAM-cabable non-CNVio radio is offered by Intel yet.
I've seen no official guidance on compatibility with chipset generations - can anyone confirm if CNVio V3 radios are compatible with 700-series PCHs / Raptor Lake-P?
Thanks in advance!
ATK03
UPDATE: I forgot that the BE200 supports 4096QAM - so at this point the question is whether Raptor Lake / 700-series PCH support CNVio V3 or only V2, and by extension whether users of that platform are better-off with the BE200 or BE201.
n_scott_pearson
700 Series chipsets do not have support for CNVio3. This support was introduced in the 800 Series chipsets. To add Wi-Fi 7 support, you will need to use one of the non-CNVi cards. This means either the BE200 or the BE202. Since, as you said, the BE202 doesn't support 4096QAM, your only choice would be the BE200.
Clear as mud?
ATK03
Fantastic - thanks for the info. It looks like I'd been misremembering the datasheet anyways - I initially thought that the BE201 was the only card yet-available to support 4096QAM, but the BE200 does as well.
I do wish Intel would clarify CNVi version support in the respective sections of their PCH datasheets - everything else there was fairly robust.
