Wireless
8335 Discussions
CONSULTA SOBRE TARJETA INALAMBRICA
RONEL_10
Deseo reemplazar mi tarjeta wifi por una wifi Intel Wi-Fi 6 AX200 tengo una laptop toshiba S45-B4186SM deseo saber si esta tarjeta inalambrica es compatible con mi laptop tengo instalada una tarjeta wifi atheros AR956X envio una imagen de la terjeta wifi instalada.
n_scott_pearson
Well, it looks like a you have a M.2 Type E connector there, so the physical connection of a AX200 module is possible. Provided the laptop's BIOS is not implementing Allow/Deny Lists to specifically exclude solutions that the vendor didn't supply, this should, in theory, work.
