I'm trying to update the PROSet/wireless tool but it keeps telling me I need to delete the older version first. It is not showing up in the add/remove list. I have also tried CCleaner with no success. I running Vista home Premium. Any help would be appreciated.
Hi SG,
I would recommend running the Microsoft* Clean up Utility, you may use the following link:
http://support.microsoft.com/mats/Program_Install_and_Uninstall http://support.microsoft.com/mats/Program_Install_and_Uninstall
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
If you continue having the same issue I would like to recommend backing up all your data and doing a fresh re-install of the operating system.
