I correctly installed the wifi card. However i cannot detect the wifi and bluetooth.
I installed the last BIOS and last drivers (for Win 7)
I attach some pictures.
msinfo32 on the NUC
Device before and after installation of wifi adapter (english translation of "Controller di rete" is "Network interface controller")
BIOS
Hi mezza35,
I am sorry you are having this problem with the system but let me help you.
All the information you have provided is very complete but I would like to know some more information about the configuration:
- Is there any possibility to test this wireless card on another system?
- Was this working fine before? If so, was there any change on the computer?
- Can you try connecting the PCIe card on PCI port C? Check the Technical Product Specification for the NUC here:
http://downloadmirror.intel.com/23090/eng/D54250WYB_D34010WYB_TechProdSpec06.pdf http://downloadmirror.intel.com/23090/eng/D54250WYB_D34010WYB_TechProdSpec06.pdf
Kevin M
1. I will try, but i don't know if i can test in another system.
2. The card never work. I get the NUC yesterday from Amazon.
3. The card is already in Port C, and in Port B i installed an m-sata memory.
mezza35
Here you have a very good link with information in how to identify the Wireless card;
http://www.intel.com/support/wireless/wlan/sb/cs-025417.htm http://www.intel.com/support/wireless/wlan/sb/cs-025417.htm
in case you are still having problems with the wireless card or it is not working correctly I recommend you contacting the place of purchase or you can contact our support chat at this link:
http://www.Intel.com/chat www.Intel.com/chat
Kevin M
When I click Device Manager, and select Network Adapters section, the Intel wireless adapter isn't listed. (see attached picture above)
Do you think that is probabily broken?
Thank you
Andrea
Can you check if the adapter is recognized on BIOS?
You can also try installing the latest BIOS update for your NUC here:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24269 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24269
Kevin M
