Wireless
7438 Discussions
Centrino 6235 : BT_2.6.1210_e64 and Windows 8 Pro : Hkey_Local_Machine32 error
Hello.
I am experiencing an hkey_local_machine32 setup error using bt_2.6.1210_e64 on Windows 8 pro.
It seems that this release is not compatible with Windows 8, despite of the ambiguous decription of this release.
(Compatible, not compatible ?).
Any idea for a solution ?
Thank you
The complete message is : &# 13; Could not open key : HKEY_LOCAL_MACHINE32\SYSTEM\CurrentControlSet\Services\BTHPORT\Parameters.&# 13; Verify yhat you have sufficient acces to that key, or contact your support personnel.&# 13; &# 13; This key does not exist in Windows 8 x64. An the message occurs even with 'run as an administrator'.
Jose_H_Intel1
Is it possible to install the available Windows* updates and try again with the Bluetooth software version I posted above?
Unable to uninstall Intel® PROSet/Wireless Bluetooth® Software
http://www.intel.com/support/wireless/wlan/sb/CS-034396.htm http://www.intel.com/support/wireless/wlan/sb/CS-034396.htm
ATaul
Hi. All available Windows updates were installed and I tried again to install BT_3.0.1304_e64.exe. Unfortunately, it did not work and I received only this error:
Jose_H_Intel1
Please try the following:
  1. Install current Windows* Updates
  2. Uninstall Intel® PROSet wireless and reboot
  3. Uninstall Intel® Bluetooth and reboot
  4. Install Intel® PROSet wireless 15.8.0
  5. Install Intel® Bluetooth 3.0.1304
If the issue persists you may consider reinstalling the operating system or contacting your system manufacturer for further assistance since your operating system might be corrupted.
