The AC 3165 NGW wireless card has two connectors labeled "1 AUX" and "2 Main". What differentiates these two connectors? Are these two connections for transmission and one for receiving? And which one to transmit and which to receive?
Thanks all.
Hello VNguy18,
Thank you for posting on the Intel ® communities.
To answer your question, the main is used for WiFi while the AUX is used for Bluetooth*, they both need to be connected to have both Bluetooth* and WiFi working. Keep in mind that we do not recommend or support wireless integration, if you are thinking of changing the wireless adapter it is recommended to contact the manufacturer of your system for assistance. More information in the link below:
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html
David V
Thanks for your answer. However, I still wonder if the connector 1 used for WiFi is a two-way connection, both transfer and receiver, right? And what is the output power of WiFi?
Hello VNguy18,
Thank you for your response.
Let me check that information for your since it is not in the common documentation we have for the product, allow me some time and I will respond as soon as possible.
David V
Hello VNguy18,
Thank you for patiently waiting.
Wireless antennas are generally provided by each computer manufacturer, as they will need to fit each computer and may be subject to country-specific regulatory requirements.
The power and field strength are dependent to the Antenna of each computer manufacturer's system therefore you have to check with your system manufacturer.
David V
Topic Options
