Wireless
8410 Discussions
DRTU tool 连接问题。
XXu7
项目需要做FCC认证,但是需要Wifi的定频软件,至少可以选择信道或模式。使用DRTU工具尝试链接WiFi的时候报错,报错内容如下:
ERROR: Connection failed Bin Commands WiFi connection failed. Reason: Exception in: Shared\UscLibLoader\LoadLib.cpp Function: xvtlibloader::LoadLib::LoadLibrary_ Line Number: 61 Description: Unable to load library with path WifiSwStack.dll system error description is :Error Code: 126. �Ҳ���ָ����ģ�顣wIFI connection error.png
请提供相关办法可以实现以上目的。使用的Wifi型号是Intel AX200。
Alberto_Sykes
XXu7, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
What is the model of the Router?
Is this a new computer?
Was it working fine before?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed in the computer?
When did the issue start?
Which Windows* version are you using?
Does the problem happen at home or work environment?
Does the problem happen just with that application?
Albert R.
A Contingent Worker at Intel
Alberto_Sykes
Hello XXu7, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
XXu7
Hi Alberto,
Problem fixed after install driver,thank you.
Alberto_Sykes
Hi XXu7, You are very welcome, thank you very much for letting us know those results.
Perfect, excellent, it is great to hear that the problem with the Wireless connection got fixed by installing the driver and now everything is working properly with the computer.
Any other inquiries, do not hesitate to contact us again.
Albert R.
