While going through the Debian 12 Graphical installation process, I have came across an error.
While detecting network hardware it says that i am "Missing firmware files" and that they are "intel/sof-ipc4/mtl/sof-mtl.ri" i can continue without these by not loading missing firmware.
after that it takes me to a page that says there is no ethernet card detected. this laptop from what i can tell does not have a ethernet card, so i click "no ethernet card"
after this it gives me another error
"no network interface was detected"
after i press continue
it allows me to continue the installation process, letting choose a host name and password, partition disks and install the base system.
after all of that is done im met with the network mirror section, here is where im met with more errors
i choose that i want to use a network mirror for faster downloads and what not. so i go through and choose what i found to be the current Debian 12.6 network mirror which is "ftp.us.debian.org"
i leave the HTTP proxy blank because i dont need that
then i get an error "Bad archive mirror"
This is because i am not connected to a network, because i dont have an ethernet card
and it wont recognize that
im not sure what to do.
Hi skopur,
I would like to apologize for the delay in our response.
Have you ever tried getting the drivers from HP?
To better understand your system's configuration, we kindly request that you download the Intel® System Support Utility for Windows* software.
You can find the download link here:
•Intel® System Support Utility for Windows*
○ Here's a quick guide on using the Intel SSU:
1. Download and launch SSU.exe.
2. Check the box for "Everything."
3. Click "Scan."
4. When the scanning is complete, click "Next."
5. Click "Save."
6. Please send the saved file to us.
This information will greatly assist us in diagnosing and addressing the specific concerns with your system. If you encounter any challenges during this process or have additional questions, please don't hesitate to let us know. We're here to help.
Dean R.
Hi skopur,
Dean R.
Hi skopur,
Dean R.
