Wireless
8384 Discussions
Device driver for Killer AX1650s 160MHz (201D2W) stopping Windows boot
KeithOfUK
I have a 11th Generation Intel(R) Core(TM) i9-11900H (24MB Cache, up to 4.9 GHz, 8 cores) with a  Killer AX1650s 160MHz (201D2W) wifi. On the 23rd June 2023 the Dell SupportAssist suggested that I update the device driver for Killer wifi; so I did. Since then I've been unable to boot my laptop.  I can get it running in safe mode + networking, but the network side is not working.   Windows 11 Device Manager's Device Status for the Killer wifi reports that "Windows cannot initialize the device driver for this hardware (Code 37) The request is not supported."
All suggestion will be gratefully received
Keith
Jocelyn_Intel
Hello, @KeithOfUK
Thank you for posting on the Intel® communities. I will gladly assist you here.
Please, answer these questions to have a better perspective of this issue:
  1. Is the Intel® Killer™ Wi-Fi 6 AX1650 the pre-installed Wi-Fi card in your laptop or is it an integration (upgrade/ not the original card)?
  2. What is the model of your laptop?
  3. Since this issue started after the driver installation that came from the Dell assistant, have you already contacted Dell regarding this issue?
  4. Perform a Clean Installation of Wireless Drivers, using the latest wireless driver
Note: Make sure to check you have all the Windows updates before doing the driver installation.
Jocelyn M.
Jocelyn_Intel
Hello, @KeithOfUK
We are checking this thread and we would like to know if you were able to review our previous post. If you need further assistance, please do not hesitate to contact us back.
Jocelyn M.
Jocelyn_Intel
Hello, @KeithOfUK
We have not heard back from you, so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Jocelyn M.
Jocelyn_Intel
Hello, @KeithOfUK
As an additional recommendation, we suggest you to contact your System Manufacturer regarding this issue.
This thread will no longer be monitored shortly.
Have a nice day.
Jocelyn M.
