I could not find any information about the differences between these 2 models of the AX210 wifi card.
Both non VPro, both M.2 2230, any temperature or industrial version expecification founded in any. Just a different recomended price in the Intel´s web. 11$ for the first and 25$ for the second.
SOLUTION:
I contacted with Intel by a different way and I obtained the required information in the beginning in this topic.
The AX210.NGWG.NV includes only the wifi card module.
The AX210.NGWGE.NVK includes the wifi card module, 2 RF cables and 2 antennas.
Hello Oscarito,
I understand that you are seeking details regarding the differences between AX210.NGWG.NV and AX210.NGWGE.NVK. I will be investigating this matter and I'll get back in touch as soon as possible.
Jed G.
Hello Oscarito,
I sent you an email to continue the support. Please check your inbox at your earliest convenience.
Jed G.
And just why are you sending the OP an email? There is no reason for this information to not be provided here. Do this the right way!
I did not receive any useful information, just the comparison between both Material Declaration Data Sheet (MDDS) that is possible to be read in the Intel webpage of the wifi card... But I did not receive any solution for the doubt.
I can´t understand why even a moderator of the forum can´t solve a basic doubt about two specific cards effectively.
Hi @Oscarito ,
I'm not sure if the AX210.NGWGE.NVK is available in stock anywhere while the AX210.NGWG.NV exists in stock.
Leon
I was discarding all the versions I see in stock in an specific shop (around 10 different of the same ax210) for not to be standard (like industrial or extended temperature, vPro version, cnvio...) and finally I had this two options as possible to buy for my situation.
The shop can´t say the difference between them even contacting with the supplier.
The AX210.NGWGE.NVK is marked as "new product", and the AX210.NGWG.NV is on stock too.
Yes, is there some reason all of us cannot know the reason?
[W10 is this generation's XP]
SOLUTION:
