Wireless
8418 Discussions
Difference of the meaning on Wifi6e AX210 card
Vich
What is the meaning of these wordings;
TA:17633-001 Vs TA:17633-003
TA:17633-002 Vs TA:17633-003
It is printed on the Wifi card M.2 AX210 Which one is better?
And what are the buying factors of these cards?
Alberto_R_Intel
Vich, Thank you for posting in the Intel® Communities Support.
In reference to your question, we will do further research on this matter in order to confirm what those numbers mean. As soon as I get any updates, I will post all the details on this thread.
The specifications are the same for the three of them:
https://ark.intel.com/content/www/us/en/ark/products/204836/intel-wifi-6e-ax210-gig.html
It is important to mention that when you install the wireless card on a laptop/board that is what is called "Wireless Integration", and the thing about that process is that there are a lot of components that come into play, like for example: board, Wireless card, drivers, PCI adapters antennas, m.2 ports, all those parts need to be fully compatible for the proper functionality of the Wireless connection. There is also regulatory information about the "Wireless Integration" that you can verify in the following links:
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless.html
https://www.intel.com/content/www/us/en/support/articles/000005846/network-and-i-o/wireless.html
Albert R.
Alberto_R_Intel
Hi Vich, I just received an update on this matter.
You can check the PCN for Intel® Wireless products:
https://qdms.intel.com/Portal/SearchPCNDataBase.aspx?mm=999LWX
And document 118689-00, that states the following:
https://qdms.intel.com/dm/i.aspx/7603DA8E-2FCD-429C-B27B-15F87288B08A/PCN118689-00.pdf
This is somehow of a lot number that is updated by Intel® and is notified through the PCN product change notification. As you can see, it does not affect the functionality or something, it just changes the number.
In the end, basically, all of them are the same products, no one is better than the other, the only change is TA number and that the Authorized Distributors handle different numbers, you can always check with them directly for further details on that topic:
https://marketplace.intel.com/s/accessdenied?language=en_US
Albert R.
