Hello, I have the Intel AX201 WiFi 6 installed in my setup. My system is a Debian based openmptcprouter (openwrt). Unfortunately, after successfully installing the drivers, I couldn't get the network card to run in AP mode so I wanted to ask whether the card even supports this mode.
root@OpenMPTCProuter:~# lspci -k
00:09.0 Network controller: Intel Corporation Wi-Fi 6 AX201 (rev 20)
Subsystem: Intel Corporation Device 0074
Kernel driver in use: iwlwifiKernel:
root@OpenMPTCProuter:~# uname -a
Linux OpenMPTCProuter 5.4.238 #0 SMP Sat Jul 29 19:00:07 2023 x86_64 GNU/Linux
Hi max93776,
Greetings from Intel Customer Support.
I understand that you are having difficulty using the Intel wireless card in AP mode. Please allow me to check what else I could be of help with.
To set your expectations, I will be asking you a series of questions to narrow down what recommendations I could provide. If you may, kindly share the following details below:
- For the record, were you able to run the Intel wireless card in AP mode before using the same setup?
- Are you using a laptop or desktop? If laptop, what is the exact make and model of your laptop? If Desktop, what is the exact make and model of the motherboard?
- May I know what the exact operating system and flavor of your system are?
- Just to confirm, is the wireless card is pre-installed on your computer?
- Have you done any troubleshooting? If so, please specify.
Furthermore, if it is possible, I hope that you download and install an Intel tool that will scan your system. Don't worry; there will be no personal information to be collected. To get the tool, please visit this link: https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html
Please run the program, select everything, then scan, click next, save the result log, and upload the text file in your next response.
I will be waiting for your response.
Hi max93776,
Just a follow-up: I see that there's no movement on this thread. With that in mind, I would like to know if you wish to be supported.
Brian T.
Hi max93776,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Brian T.
