I am using 4 laptops with the following NICs:
Intel AX200 Intel AX210 Intel AX201 Killer WIFI6 AX1650x
With a mix of win 10/11 updated or not.
With 3 different Asus ax92u (Wi-Fi tri-band 4x4 ac/ax) in Access Point mode.
I have tested all possible combinations software/hardware, one change at a time
Using the Intel driver 22.100.1, no problem, all are connected to AX.
I soon as I upgrade to 22.110.1 or 22.120.1 they ALL connect to AC only.
There is no specific error in the Event Log.
Other devices with non-intel WIFI card connect with AX .
All Intel cards connect to AX with Ubuntu...
I came to the conclusion that is a driver issue and seems to be a problem of negotiation between AX and AC with drivers 22.110 and 22.120 (windows)
This is NOT a problem of installation, setup...
Need some help here…
Thank you.
