Hello!
Microsoft started sending your new driver version 22.190.0.4 and 22.200.0.3 using Windows Update. If you look at the structure of the driver, you will see that the names of the reference device names have shifted from their proper place to the very bottom of the configuration file. View attachment.
You upload the drivers to the Microsoft repository and the responsibility lies on your shoulders, that is, Intel!
Please fix this bug. This bug is present only in the driver and it is not visible in the system, i.e. it is not critical.
22.190.0.4: Intel Download Center / Microsoft Update Catalog (Identical files byte by byte)
22.200.0.3: Microsoft Update Catalog
update
I noticed that the status was set by you:
Closed: Final |
Topic Options
