Wireless
8787 Discussions
Driver 22.190.0.4 deleted the reference device names
imvagsig
Hello!
Microsoft started sending your new driver version 22.190.0.4 using Windows Update. If you look at the structure of the driver, you will see that the names of the reference device names have shifted from their proper place to the very bottom of the configuration file. View attachment.
Please fix this bug. This bug is present only in the driver and it is not visible in the system, i.e. it is not critical.
I have already reported a similar problem to you before and you fixed the problem.
AndrewG_Intel
Hello @imvagsig
Please allow us to look into this and we will be posting back in the thread as soon as more information is available or in case additional details are required from your environment.
Andrew G.
AndrewG_Intel
Hello imvagsig
We would like to thank you for sharing this information with us and inform you that we have shared this information with our engineering team about it to make the necessary change in upcoming releases.
Having said that, we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Thank you for your time and efforts in this matter.
Sincerely,
Andrew G.
imvagsig
Hello!
A similar problem with the new driver 22.200.0.3.
