Wireless
6690 Discussions
Dual band wireless-ac 3160 stopped working
MW8
This product, previously working away, installed from the original equipment provider (Dell) suddenly has ceased to operate. I tried reinstalling the driver, to no avail. Are there other methods of troubleshooting the adapter?
I ran the SSU.exe and can provide the output if that would help.
-MW8
Alberto_Sykes
MW8, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
If this is a laptop, what is the model of it?
What is the model of the Router?
Is this a new computer?
Was it working fine before?
When did the issue start?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed on the computer?
Which Windows* version are you using?
Does the problem happen at home or work environment?
Please provide the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
MW8
Albert,
Happily, I have succeeded in returning the Intel adapter to regular operation. As a result, I ask that we suspend this conversation, with much appreciation in your quick response
MW8
LandoG
Hello MW8,
We both appear to be having a similar issue.  I suspect my problem is a driver issue as well.  What process did you undergo to sort out this issue?
Kind regards,
LandoG
MW8
LandoG,
My system is running Windows 10.
  1. I connected via the system Ethernet port to gain Internet access.
  2. Despite the driver being up to date, I downloaded and reinstalled it once more. That didn't appear to change anything, but it may have done so.
  3. Next, in the Settings application, I accessed the Network & Internet section, and although I was connected via wired Ethernet, the settings offered the "Show available networks" option. While that option had not been responsive when I was struggling with wireless, it now allowed me to see local wireless networks.
  4. I selected my Wi-Fi network and supplied the network key, which resulted in the network connecting.
  5. When I removed the Ethernet connection, my Wi-Fi network persisted.
Best,
MW8
Alberto_Sykes
MW8, Thank you very much for letting us know those results.
Perfect, excellent, it is great to hear that you were able to return the Intel® adapter to regular operation and now it is working properly.
Any other inquires, do not hesitate to contact us again.
LandoG, Thank you for posting in the Intel® Communities Support.
Please submit your inquiry on a new thread, the reason for this is that every scenario is different even if the same product is being used, so for us to better assist you and in order to try to fix the problem, please submit a new thread:
https://communities.intel.com/community/tech
Let me apologize for any inconvenience.
Albert R.
