While I was downloading one of the wifi driver of the intel, installer has crashed so I had to shut it down from task manager. After I shut down the installer I restarted pc and tried to open installer again but Failed to Parse Setup.Xml error was kept coming of then I searched error and finally solve it with silent install. But after 2 days while I was downloading another intel driver this error came of again, I don't want to make silent install everytime can someone help me without silent installing.
I tried to install again with silent install but this time silent install doesn't worked too, so I am desperate right now
Hello @Eren19
In order to check this behavior further, could you please provide the following information?
1- Is the Intel® Wireless adapters the original adapter that came pre-installed in your system or did you install/integrate it on the system?
2- Please provide the step-by-step details on how you are installing the drivers (both, normal install and silent install).
3- Since you mentioned the Silent install is not working at this moment, are you getting the same error message? (Failed to Parse Setup.Xml)
4- Please shared the links that you are using to download the drivers experiencing this behavior.
5- please run the Intel® System Support Utility (Intel® SSU) and attach the report to this thread to gather more details about your system.
Note: To attach a file, you must click the “Attach” option on the bottom left-hand corner of the response box.
Andrew G.
Hello Eren19
We would like to know if you were able to review our previous post. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Hello Eren19
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer being monitored.
Andrew G.
For more complete information about compiler optimizations, see our Optimization Notice.
