Wireless
8711 Discussions
HP Spectre 13t-3000 CTO with embeded Intel Bluetooth (Intel AC 7260) Connectivity Issues
JBreu1
In April 2014, I purchased an HP Spectre 13t-3000 CTO Notebook. Installed is the the Intel Dual Band Wireless-AC 7260 WiFi and Bluetooth adapter.
On HP's support website, the latest driver for the Wireless LAN driver is Version 16.6, 215.11M dated 05NOV2013, and the latest driver for the Bluetooth is Version 1.00, 60.86M dated 01NOV2013. With this driver, I experience intermittent connectivity issues with a Microsoft Wedge Mouse and a Canon ip100 Printer with an installed Bluetooth adapter.
Intel's support website detected an updated driver for both the Wireless LAN and Bluetooh. I updated both drivers to version 17. 1.0.19 and 17.0.1405.0464 respectively.
Unfortunately, I still have the same results. I will print a document over the Bluetooh connection, and it stops responding and only prints a partial page.
I know that the Canon ip100 with Bluetooth adapter is functioning properly because I also have a Microsoft Surface Pro with the same Canon printer driver software installed as on the HP Spectre, and I am able to print through the Bluetooth without any problems.
So, the problem lies within the Intel Bluetooth hardware or drivers on the HP Spectre.
Thank you!
Kevin_M_Intel
Hello AverageJoe,
Based on the information you have provided, there are many things can be causing the issue but I need more specifications about your system configuration.
Can you please provide your dxdiag report here? How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Attach using Advanced Editor Options.
You also said you replaced the previous Bluetooth and wireless adapter, can you please let me know the adapter brand/model you had before?
Kevin M
JBreu1
Hello Kevin!
Thanks for the help! The USB Bluetooth Adapter mentioned and in question is made by Canon, Bluetooth Unit BU-30, and is designed to plug into an internal USB port on the Canon Pixima ip100 inkjet printer, and possibly other Canon models. When I try to print via Bluetooth the Canon ip100, the print job starts, but never finishes. I receive the following error:
I compared all of the settings from my Surface 3 and the HP Spectre 13t-3000 that I am having difficulty printing from. All of the Bluetooth settings look identical.
The Basic Printing Profile (Direct Printing) and Imaging (Responder) are Intel Drivers Version 17.0.1405.446 dated 26MAR2014. The re
Again, thank you for all your help!
The following is from the Dxdiag Report as requested:
System Information
Time of this report: 10/16/2014, 18:32:23
Machine name: SPECTRE-13
Operating System: Windows 8.1 Pro with Media Center 64-bit (6.3, Build 9600) (9600.winblue_r3.140827-1500)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: HP Spectre 13 Ultrabook
BIOS: F.13
Processor: Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz (4 CPUs), ~2.4GHz
Memory: 8192MB RAM
Available OS Memory: 8124MB RAM
Page File: 2350MB used, 13965MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 192 DPI (200 percent)
DWM DPI Scaling: UnKnown
DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics Family
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0A16&SUBSYS_1911103C&REV_09
Display Memory: 1792 MB
Dedicated Memory: 0 MB
Shared Memory: 1792 MB
Current Mode: 2560 x 1440 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: unknown
Monitor Id: LGD0000
Native Mode: 2560 x 1440(p) (60.075Hz)
Output Type: Internal
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 10.18.0010.3383 (English)
Driver Version: 10.18.10.3383
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 4/25/2014 21:32:24, 19950592 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4956-11CF-BB7E-1B39B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0A16
SubSys ID: 0x1911103C
Revision ID: 0x0009
Driver Strong Name: oem27.inf:5f63e5341cc65b69:iHSWM_w81:10.18.10.3383:pci\ven_8086&dev_0a16&subsys_1911103c
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_Y...
Kevin_M_Intel
So I just want to confirm more things with you.
If you connect the printer and keep it on/ connected but not printing, does the printer stay connected all the time? You can Check this on PC and Devices > Bluetooth.
If printing, does the printer stays connected as well?
Kevin M
JBreu1
Thank you, Kevin, for all of your help!
I finally got it to work! So, when you first pair the Bluetooth Canon Pixma ip100 through Windows 8.1 Pro, Windows goes out and grabs all of the required drivers from Canon and configures on "BTH001 Virtual printer port for Bluetooth", as it did for my Surface Pro 3 with a different manufacture for the Bluetooth.
However, my HP Spectre 13t-3000 CTO with integrated Intel AC 7260 Wi-Fi/Bluetooth, there is a second Bluetooth Printer Port option labeled "BTM001 Bluetooth Printer Port". I am not sure if this is Intel specific or not. I selected this port and was able to make three successful "Print Test Page" without any problems.
Again, thank you for all of your help!
Kevin_M_Intel
JBreu1
Okay... so the saga continues. Long story short, HP replaced the motherboard in my HP Spectre 13t-3000 under warranty. After I received the notebook back from repairs, it now has an Intel Wireless-N 7260. I also picked up a an HP EliteBook 820 with an Intel Dual Band Wireless-N 7260. Slightly different models, but they both fall under the same driver package.
Going back to my original story, I have a Canon Pixma iP100 portable printer with a Canon BU-30 USB Bluetooth adapter installed. Attempting to print via Bluetooth and the Intel drivers for both notebook, the printer starts out and after printing about 1/10th of the page, the print job stops. Eventually, I receive an error message that the print job could not be completed. The printer requires bidirectional communication. Somewhere in the Intel driver/software package, this bidirectional communication stops.
So, how do I know this an Intel related issue? Well, under Device Manager, I changed the driver to "Generic Bluetooth Adapter" for both notebooks. The printing works without any problems using the generic drivers. Again, the printer requires bidirectional communication set up for the Bluetooth as COM3 for Incoming and COM4 and Outgoing.
How do I go about getting this information up to Intel to work with the team that writes the drivers?
Thanks!
Joe
Kevin_M_Intel
I understand and I am really sorry for all this inconvenience.
We have developed a new driver. Can you please try it?
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24576 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24576
If you are still having problems with the card, please contact our phone support:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Kevin m
JBreu1
Hello Kevin,
Thank you for the help! For both the Intel Wireless-N 7260 and the Intel Dual Band Wireless-N 7260, I had already attempted the 17.13.11 version driver (latest) without any success. On both notebooks, I have a Microsoft Wedge Bluetooth Mouse connected, and the Intel Bluetooth drivers appear to work. The issue only comes into play when attempting to print through the Bluetooth with the Intel drivers. With generic drivers, both devices simultaneously connected work without any problems.
Thank you,
Joe
