Dear,
Can i capture the beacon frames of surrounded APs using the AX200 Wi-Fi6 adapter or other adapter on Windows?
How can I capture 11ax packets with Intel adapter ?
Hello Yukino,
1. Can you confirm what are you trying to accomplish? Are you looking to administrate a network at some level?
2. Would you like to capture beacon frames only or other types of packets also? Is this for Wi-Fi 6 only? Please include more details.
3. To have all information, can you fill the "Intel-Wireless-Customer-Checklist" document attached? You can skip all the personal information and just provide the issue and system details.
4. Additionally, run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
- Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
Sebastian M
Have you looked at or tried Wire Shark? That thing is amazing at what it can capture.
I have set the type of adapter to monitor.
Of course, but i cant capture 802.11 frame, such as beacon, assoc req/resp.
Hello Yukino,
After double-checking this internally, we noticed that Intel does not have a tool to make this type of network captures. You may want to consider checking in different networking specialized forums for further help.
You can consult with Microsoft* to see if at the Operating System (OS) level they may have a tool like this.
On the other hand, maybe your router/AP manufacturer can help you with a similar feature from their side.
I will proceed to close this inquiry. If you have any additional questions, please submit a new thread as this one will no longer be monitored by Intel.
Sebastian M
