Wireless
8563 Discussions
How does the BE200 MLO work?
oTobi
Hi!everyone.
Im using a Intel(R) Wi-Fi 7 BE200 320MHz on my PC,and  its win11 _24H2.When the PC in an environment with many SSIDs,means Strong interference,BE200 MLO is work.But in an environment with a few SSIDs,BE200 MLO is not working.Is this the logic of the BE200,Use MLO only in highly intrusive environments?Look forward to someone told, thank you
ACarmona_Intel
Hello oTobi,
Please allow me time to gather more information regarding your concern so I can provide you the appropriate answer to your query.
I will get back to you as soon as I already have an answer.
Carmona A.
ACarmona_Intel
Hello oTobi,
Thank you so much for patiently waiting on my response.
In order for me to provide you the appropriate answer to your query, please provide the following information below:
1. Is your device a laptop or desktop? If a laptop, what is the brand and model of this device?
2. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently? If the wireless card is pre-installed on the system, Is it possible that you can share with me where you obtained the wireless driver?
3. What is the brand and model of the access point that you're using?
Carmona A.
ACarmona_Intel
Hello oTobi,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
Hello oTobi,
This is only a quick follow-up; I just wanted to check in with you, as I haven't received any feedback from you.
Thank you.
Carmona A.
ACarmona_Intel
Hello oTobi,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still need assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
