Wireless
8628 Discussions
How to attach antennas to Intel 8265NGW network adaptor? special tool?
EStri1
David_V_Intel
Hello EStri1,
Thank you for posting on the Intel ® communities.
If this unit is a desktop kit then you can refer to the link below for instructions on how the integration goes. It shows step by step on how to properly install the adapter:
https://www.intel.com/content/dam/support/us/en/documents/network-and-i-o/wireless-networking/8265_DT_Integration_Guide.pdf
However, if the unit you are trying to install is not the desktop kit, it is recommended to contact the system manufacturer so they can guide you through the process and tell you if this is a validated adapter for use with that system, this is also important because the wireless adapter must comply with the regulatory information of hardware installation or upgrade.
More information in the link below:
https://www.intel.com/content/www/us/en/support/articles/000005687/network-and-i-o/wireless-networking.html
I hope this helps.
David V
A Contingent Worker at Intel
EStri1
Yes, the pdf pics you sent show exactly that you just press the antenna end down on the adaptor. Thanks
David_V_Intel
Hello EStri1,
Thank you for your response.
You are very welcome, I am glad I was able to help. Contact us back if you need any more assistance.
David V
