Wireless
8787 Discussions
How to set NoA for a GO of Wi-Fi P2P in Intel(R) Dual Band Wireless-AC 8265?
JoySnow
目前,我通过下面的API创建了一个P2P的GO,
WiFiDirectAdvertisementPublisher mPublisher = WiFiDirectAdvertisementPublisher(); mPublisher.Start();
我想配置NoA(缺席通知),但找不到相应的API,有人知道方法吗?任何帮助将不胜感激。
Alberto_R_Intel
JoySnow, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Were you able to properly configure NoA (Notification of Absence) on this specific machine before?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
The wireless card, did you purchase it separately or did it come installed on the computer?
Are you using your computer at home or in the work environment?
Albert R.
JoySnow
Question1: Were you able to properly configure NoA (Notification of Absence) on this specific machine before?
Answer1 : I don't know how to configure NoA on the computer.
Question2: Did you make any recent hardware/software changes that might cause this problem?
Answer2 : I made no hardware or software modifications.
Question3: The wireless card, did you purchase it separately or did it come installed on the computer?
Answer 3:  On the computer.
Question4:  Are you using your computer at home or in the work environment?
Answer4:  Work environment.
I am currently unable to provide relevant logs. What I want to know at the moment is whether there is a way to disable Notification of Absence, and what conditions will trigger Notification of Absence.
Jocelyn_Intel
Hello, @JoySnow
I hope you are great.
I am checking this thread and I would like to know if you were able to review the previous post.
Jocelyn M.
Alberto_R_Intel
JoySnow, Thank you very much for providing those aspects.
No problem at all, we completely understand that you are currently unable to provide relevant logs. I will do further research on this matter in order to try to supply the details that you are requesting about the "Notification of Absence". As soon as I get any updates, I will post all the information on this thread.
Albert R.
Alberto_R_Intel
Hello JoySnow, I just received an update on this matter.
After reviewing the case, we just wanted to let you know that for this configuration it is necessary to check for third-party applications or use the ones possibly recommended by the manufacturer of the computer since WiFi-direct relies on the Operating System itself.
Albert R.
