Wireless
8335 Discussions
I am using ASUSTeK COMPUTER INC. FX503VM. My problem is my Wireless-AC 8265 keeps dropping
Ompong
The drivers I am using are as follows:
Intel® Wireless Bluetooth® for Windows® 10
Installed Version: 21.50.0.1
Manufacturer: Intel Corporation
Driver Date9/6/2019
Device Id: USB\VID_8087&PID_0A2B&REV_0010
Intel® Dual Band Wireless-AC 8265
Windows® 10 Wi-Fi Drivers for Intel® Wireless Adapters
Installed Version: 20.70.13.2
Device Id: PCI\VEN_8086&DEV_24FD&SUBSYS_00108086&REV_78
Any updated fix for this problem ?
AlHill
Use the drivers provided by Asustek.
Doc
Ompong
Doc,   Thanks for immediate response.   Originally installed are Asustek drivers but WiFi kept dropping. When I turned to Microsoftcommunity about this “dropping” problem, it was suggested that I upgrade to thelatest  Intel driver version which I did about TWO weeks ago.Still, the problem persist. Any other suggestion ?   Regards,   Ompong Babate BasTech Trading Cellphone #: +63 929 6050 439 (SMART)                      +63 916 2716 049 (Globe)
AlHill
Microsoft should stay with OS support.
Are you using a wireless mouse and/or keyboard?
If so, you may want to set your 8265 connection to the 5ghz band.
Also, your phone numbers are unnecessary and you should remove them.
Doc
